Spark Plugs From Hell
Old Jul 13, 2014 | 11:45 AM
tlxxtl's Avatar
tlxxtl
Default Spark Plugs From Hell
Hello all, as a newbie here and first time Corvette Owner(1989 White with Black interior) vette.jpg decided to read here first and conquer the task of a tuneup( plugs , wires, cap and rotor) I began at 8am CST and followed the instructions from the forum I purchased NGK IX plugs (side bar: when purchasing plugs for cars that use different heads take one of the existing plus out first to confirm that the new plug will fit) I went to Advance Auto and ordered what it showed to be the correct plug the day before, they were wrong took them back and got the tr55ix they fit. Well 8 hours and many @#$$#%%^ later. I was done. MY TIP FOR ANYONE NEW TRYING TO DO THIS. remove the passenger side third plug wire ( the straight one), use the end of the plug wire to hand tighten the new plugs. This save my sanity as the third and fourth plug on the passenger side went right in using this, it did take me several hours to find this out. Now it time to change a squeaky rear caliper.
Old Jul 13, 2014 | 12:20 PM
383vett's Avatar
383vett
Welcome to the Corvette world. Wait until you try the water pump.
Old Jul 13, 2014 | 12:27 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Welcome and congrats on your new '89 Vette.
FYI, doing the right bank is much easier if you first remove:
-the two AIR tubes
-the A/C compressor brace
-the inspection panel on the inner fender well
Old Jul 13, 2014 | 12:53 PM
leesvet's Avatar
leesvet
Think he outta go clean and tighten his G104 grounds?
May as well while he's got the band-aids out...
Welcome to my world !
I'll say it again,
I bleed as well as anybody ! I have more leaks than the car does. Guess that's the point ~
Old Jul 13, 2014 | 01:26 PM
John A. Marker's Avatar
John A. Marker
Welcome to the Forum. I found that with my 85 it was easier to get plug #8 out from under the car by using a plug socket with the hex on the end so you can get a wrench on it.
Old Jul 13, 2014 | 02:54 PM
81c3's Avatar
81c3
[QUOTE=tlxxtl;1587349168. MY TIP FOR ANYONE NEW TRYING TO DO THIS. remove the passenger side third plug wire ( the straight one), use the end of the plug wire to hand tighten the new plugs.[/QUOTE]
One of the oldest tricks in the book is to use a length of rubber fuel hose or similar to start plugs into their bores... wish I coulda' told ya that before hand.
Old Jul 13, 2014 | 06:32 PM
tlxxtl's Avatar
tlxxtl
Thanks for the support... Is there any tips for a rear squeak? I am thinking rear brakes, possibly the caliper not functioning correctly.
Old Jul 13, 2014 | 09:07 PM
pezter22's Avatar
pezter22
I recently purchased this extender that is pretty nifty which I used to reach the no. 8 spark plug.
Old Jul 13, 2014 | 11:56 PM
tlxxtl's Avatar
tlxxtl
Nice
Old Jul 14, 2014 | 02:39 AM
Black LS2's Avatar
Black LS2
Bummer!
On an L98, the simple way is a short 1" extension, and one of the Stanley twist or rotator ratchets (89-962). Kobalt has one too.
The other tip is on plug #2: drill a 1/2 inch hole just left of the cover for the right upper control arm, directly inline with #2 plug. Use an extension, and the ratchet in the wheel well; took me until 1995 to figure that one out. It is possible to do an L98 plug change well inside of 45 minutes, even shorter.
Sorry you had such a rough go of it.
Old Jul 14, 2014 | 06:19 AM
hcbph's Avatar
hcbph
Default Tools
I found something called a Sidewinder several years ago. It's a ratchet wrench with a T-Handle on it. You can use it like a regular ratchet wrench plus if you don't have enough swing to turn it you can use the T-handle to turn the socket further. I haven't used it yet on a Corvette but I have on my older T-Bird and it worked out for me.
Old Jul 14, 2014 | 07:07 AM
Cajun CB's Avatar
Cajun CB
Be careful. The previous owner may have put the wrong plugs in over the past 25 years or so.
I found my 86 to have aluminum head plugs in a cast iron head. The reach of the plug and sealing are VERY different.
Old Jul 14, 2014 | 11:41 AM
65Z01's Avatar
65Z01
I use that "trick" except come down from the top, with one finger on the end of the plug socket to keep it from falling onto the starter...
Old Jul 14, 2014 | 02:20 PM
tlxxtl's Avatar
tlxxtl
How can I tell which heads are on my car? mine are painted black.
Old Jul 14, 2014 | 09:05 PM
Cyclonite's Avatar
Cyclonite
Still not as bad as doing the plugs on a F-word 150 with the Triton engine.... Special "long shank" plugs that "frequently" break while trying to remove them.... so much that there's a special tool that cost (at the time) about $160 to extract the broken plugs.
Welcome to "Bloody-Knuckles" garage
Old Jul 15, 2014 | 12:08 AM
383vett's Avatar
383vett
Magnet
Old Jul 15, 2014 | 03:31 PM
tlxxtl's Avatar
tlxxtl
DUH...#$%^&* Will try it. Thanks MAGNET...LOL
To Spark Plugs From Hell
Old Jul 17, 2014 | 02:00 AM
Cliff Harris's Avatar
Cliff Harris
...or the ultimate challenge, a heater core.
Old Jul 18, 2014 | 01:48 PM
Rohn's Avatar
Rohn
Sears sells a socket wrench set called max access. the socket allows the plug to pass through it and the wrench then holds socket at the socket middle outside. worked like magic on my vette with headers. I am sure you can buy the wrench and socket individually.
Old Jul 19, 2014 | 01:40 PM
HlhnEast's Avatar
HlhnEast
I am going to get a T shirt made saying "I hate #8". Probly sell a bunch here!
