Change in Early C4 Digital Clusters......
Old Jul 25, 2002 | 08:47 AM
Husker Vette's Avatar
Husker Vette
From: Are you the bug or are you the windshield.....
Default Change in Early C4 Digital Clusters......
A Friend of mine was in an accident a few weeks ago about 200 miles from home. He called the sherrifs office that has his car impounded to get the mileage and they told him that they were unable to read the odometer because it was a digital display odometer.
His car was an 86, but my 86 has a mechanical odometer in the upper right hand corner of the cluster, and the trip is a digital read out.
Was there a time during the eraly version of the C4s that the odometer was a digital readout?? Or were they all mechanical??
Old Jul 25, 2002 | 08:51 AM
Aaron71771's Avatar
Aaron71771
Default Re: Change in Early C4 Digital Clusters...... (Husker Vette)
All 86's were mechanical, they probably just figured since it was a vette it was digital like the 90's and above.
I think in 86 the only things that were changed on the dash were the angle of the dash (to better reflect sunlight) and the addition of a photoresistor to adjust dash brightness based how dark it was outside.
Old Jul 25, 2002 | 08:53 AM
Husker Vette
Default Re: Change in Early C4 Digital Clusters...... (Aaron71771)
Thanks for the reply. That is what I was thinking, but I have been wrong on issues like this before so I thought I would go to where the knowledge is.
Old Jul 25, 2002 | 10:10 AM
scorp508's Avatar
scorp508
An upshift light was also added to the tachometer pane.
Old Jul 25, 2002 | 10:17 AM
vettmech's Avatar
vettmech
Default Re: Change in Early C4 Digital Clusters...... (scorp508)
Interesting........my 85 has that photoresistor too.......... and I have seen a LOT of 86 stuff on the car ........... but it's titled as an 85......... and when I bought a top for it I specified 85 and the used top I got was off an 85 and guess what ..........it didn't fit .......... (I modified it to fit though) so the body is definitely later than it's titled .........I figure it's been stolen and recovered or rebuilt somehow but it runs great and I have a clear title so screw it :seeya
Old Jul 25, 2002 | 10:28 AM
scorp508's Avatar
scorp508
Default Re: Change in Early C4 Digital Clusters...... (vettmech)
What is the VIN?
Old Jul 25, 2002 | 11:03 AM
vettmech's Avatar
vettmech
1G1YY0780F5103169 :seeya
Old Jul 25, 2002 | 11:11 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
That's an '85 VIN. And fairly early at that.
Old Jul 25, 2002 | 11:21 AM
Aaron71771's Avatar
Aaron71771
Default Re: Change in Early C4 Digital Clusters...... (Ray Quayle)
They may have chaged the dash angle and added the photoresistor in 85. I could be off by a year.
Old Jul 25, 2002 | 11:23 AM
scorp508's Avatar
scorp508
:yesnod: :yesnod:
Old Jul 25, 2002 | 11:26 AM
vettmech's Avatar
vettmech
Default Re: (scorp508)
Thanks Scorp.......I knew the VIN was ........I just can't figure all the 86 stuff on the car and the top wouldn't fit like I said............ OH BTW when I repainted the top it was dated under the headliner as sometime in 83!!!!
thanx again :cheers:
Old Jul 25, 2002 | 11:27 AM
scorp508's Avatar
scorp508
The top thing is interesting. There are 3 style tops.
1984 - Early 1986
Late 1986 - 1988
1989 - 1996
You should check out the stamp on the engine block to see if it matches your VIN.
Old Jul 25, 2002 | 11:32 AM
vettmech's Avatar
vettmech
That's a weird thing too because it's etched like with an engraver but the casting dates are all 84
To Change in Early C4 Digital Clusters......
