Distributor Upgrade Please help.
Old Jul 25, 2002 | 09:34 AM
trupp's Avatar
trupp
Default Distributor Upgrade Please help.
Has anyone upgraded their distributor to the newer external coil HEI distributor? If so, what is involved?
Old Jul 25, 2002 | 11:23 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Distributor Upgrade Please help. (trupp)
I just installed the HyperTech coil/cap/rotor for a boost to 53kV, and up to high RPM. This with a good set of wires and plugs provides solid spark up to the L98 rev limit and beyond.
Old Jul 25, 2002 | 01:56 PM
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
All the wire colors are the same. The plugs are different, and the pin locations are reversed. I cut the plugs of a donor vehicle that I got the distributor from. Then I cut the plug off the original distributor and soldered the two together watching the wire colors. That way I didn't cut the cars harness. There's a 2 wire harness that connects the distributor and the coil. Get that from the donor vehicle. Then the power/tach plug for the coil will get soldered to the other connector for the external coil. Once again, match up the colors.
Works great.
Old Jul 25, 2002 | 02:02 PM
trupp's Avatar
trupp
Default Re: Distributor Upgrade Please help. (SloRvette)
Thanks for the help, it is greatly appreciated.
To Distributor Upgrade Please help.
