Lowering 1992 Corvette?
https://dl.dropboxusercontent.com/u/1634366/align.pdf
Note that to get this on the front you'll need to not use the rubber bumpers in the kit AND remove the rubber pads from the ends of the springs. I'd like to say that there is another way, but short of modifying the lower control arms there is not. I can't say that I recommend this - but it's working for me and many posts I've found about this method date back many years with none since indicating that this led to problems.
I can see how this might result in negative camber. I'm hardly an expert, but I agree that the car doesn't "look" like some do after lowering, where you can literally see the change in camber. When I find the time I'm going to attempt the alignment from the link that I provided, but not this weekend.
I spent the day at the Car Craft Nationals in St. Paul (awesome as always - those who have never been should make the trip some time). Tonight I'm dropping the ride height on the wife's Audi - maybe into tomorrow depending on how difficult that process becomes. Never done it before, but how difficult can it be, right? I put off lowering the Corvette for quite a while before digging in and honestly the great result has encouraged me to do the same with the Audi. We'll see...
Cut stock center spring rubber, shims removed and cut down the spring end pads. 10" lowering bolts in the rear.
Nice ride and Awesome handling with 19x10" wheels 285/30/19 Continental tires and no front spoiler lip scraping...if angled out of the driveway...
I'd considered trimming outer sections of the air dam to match the center (about a half-inch shorter in the center) to afford a little more room if need be, but I find that if I'm careful I don't scrape often enough or hard enough to be concerned.
I don't find any loss of "comfort", but being an '84 mine wasn't all that comfortable to begin with so maybe this is something a guy with a later C4 might experience. I will say that the first two weeks or so the front springs creaked when articulating the suspension - in and out of the driveway and that sort of thing. They've settled in and they don't creak anymore.
This is the best $20 modification you can make to your C4 in my opinion. Once you get your car down where it should be (IMHO) you'll be amazed how high the non-lowered C4s look.
We got the car about a year ago and I looked at a whole lot of C4s on the internet. I was in the market for wheels and tires and also in search of something to enhance the appearance of the raised center of the hood. I saved a whole lot of images of cars that I especially liked and in the process I came to realize that all of these had one thing in common - they've all been lowered. That wasn't immediately obvious to me, but they all had the "it" factor that was all about how the wheel and tire fit the wheel well. For me it's not so much about how close to the ground the car rides, but how the wheels and tires fit the wheel wells.
To each his own, but I absolutely LOVE the improvement to appearance that this has made in my case. It has probably improved handling too, but it's a street car that already handled well so I don't have any objective way to assess this. What I can say is that it handles at least as well as it did.
