Buying an optispark
Old Jul 30, 2002 | 12:16 PM
konroh's Avatar
konroh
Default Re: Buying an optispark (rubyred93)
is the apora pump from autozone any good? They are $133 with a lifetime warranty...has anyone put one of these on their vette? I don't want to get one that will fail anytime soon though, so maybe I will just go with the gm part anyway...
time to spend some money!!
Old Jul 30, 2002 | 01:03 PM
John Row's Avatar
John Row
Default Re: Buying an optispark (konroh)
I can recommend going to a Meziere Electric water pump. It uses your old housing. I got the Heavy Duty model from SpeedDemon for about $220 (plus another $15-20 in electrical parts). It's an easy installation. It adds 8-12HP (dyno verified).
Old Jul 30, 2002 | 01:12 PM
Rick93Z07's Avatar
Rick93Z07
Default Re: Buying an optispark (John Row)
The price you got of $277 is good, but it's invalid. Those guys at gmpartsdirect tack on a 25% handling/shipping fee. If you can figure out how to get one without them "handling it", good luck. I'd call Jeff Kopp at Superior Chevrolet.
Old Jul 30, 2002 | 01:55 PM
SonnyinVA's Avatar
SonnyinVA
if this gets you 8-12 hp at only a little bit more $$ than doing the GM waterpump... sounds like a deal!!
Old Jul 30, 2002 | 05:12 PM
konroh's Avatar
konroh
I just did a little research on that pump, and i think i will get one. What is the difference between the standard and heavy duty pumps? How about reliability? I usually don't take very long trips in the vette, but if i do i want to get there without breaking down!!
Old Jul 30, 2002 | 06:12 PM
John Row's Avatar
John Row
The HD is a little longer and pumps higher volume, I think I heard about 25-30% more. If you're in a hot climate then go for the HD. Meziere says something like 2000 hours MTBF. At 40 mph that's like 80,000 miles.
It comes with a wire set that includes a 20amp inline fuse. I've heard of 2 instances where the fuse holder melted and the pump stopped. When I did the installation I cut it out and put a 20 amp automotive fuse back by the battery.
Old Jul 30, 2002 | 06:27 PM
konroh's Avatar
konroh
does the larger heavy duty unit fit in a corvette without any modifications?
Old Jul 30, 2002 | 09:08 PM
TimC's Avatar
TimC
CI 3-4-6-8-9 Veteran
John...please post if this fixes it. Sounds exactly like my problem. Thanks.
Sounds like it's acting a bit like mine. Mine is very intermittent and the hotter the engine compartment gets the more it misses. At idle it will jump 500 rpm every 5-10 seconds.
If it's missing on the highway and I mash the gas, after an initial stutter it will take off and run smooth for a couple of minutes.
Mine has been getting worse. 6 weeks ago we noticed the odd idle.
Just got the new opti yesterday, next Monday the car goes under the knife!
Old Jul 31, 2002 | 02:33 AM
1996man's Avatar
1996man
Default Re: Buying an optispark (TimC)
guys wouldnt it just be easier to get an after market ignition system that works better than the opti and isnt as sensitive to water?
why isnt this done commonly? is there more to it than that?
Old Aug 1, 2002 | 12:07 AM
konroh's Avatar
konroh
does anyone have experience with CSI waterpumps?
http://www.csiperformance.com/waterpumps.html
they look like they are only about $135...are these suitable for the street?
Old Aug 1, 2002 | 12:19 AM
konroh's Avatar
konroh
i also noticed they said 1993-1995 camaro and firebird only...anyone know why only those cars and those years?
I sent an email to them asking about this...hopefully I will hear from them tomorrow.
