4+3 trans problem
Old Jul 23, 2014 | 10:45 AM
ForceFedC4's Avatar
ForceFedC4
Originally Posted by FOURSPEEDVETTE
drop me a pm. I have the old one out of my 85 that is in perfect shape. .
Awesome, I will check it out as soon as I can get the car up on some ramps again, thanks!
Old Jul 23, 2014 | 01:24 PM
powerpigz-51's Avatar
powerpigz-51
If you take the clutch rod out, the slave will bottom out on the clip that holds the piston in. If you can get a hard pedal this way, the problem is not in the bleed. Be careful, if you press too hard you will blow the clip right out of there.
