Do i need cats
Old Jul 26, 2002 | 12:13 AM
ZRWANABE's Avatar
ZRWANABE
Cruise-In III Veteran
Default Do i need cats
if i remove my cats will it help or hurt my car
we dont have inspection here
It helped out my 91 z bu im not sure with the Lt1
Old Jul 26, 2002 | 01:23 AM
vader86's Avatar
vader86
Default Re: Do i need cats (ZRWANABE)
You might lose just a bit of torque off the line but youd gain hp further up in the band. Wont hurt anything.
Old Jul 26, 2002 | 03:06 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
I'm sure some of the LT1 guys will chime in but in Lingenfelters small block Chevy book he says they (the cats) cost about 10hp on an LT1. Dunno if it will cost you elsewhere if you remove them like vader 86 suggests - it might though.
I expect you'll be quicker without than with though..
Old Jul 26, 2002 | 10:09 AM
1991Z07's Avatar
1991Z07
Then again, why mess with it? With the high-flow cats that are on the market today you can stay legal and fast.
Here in Texas I can't get the inspection done if the cats are not in place. Besides, it's really fun to beat the pants off of someone, then have them look over/under the car and see that it has a full exhaust system...including cats.
Old Jul 26, 2002 | 10:59 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Default Re: Do i need cats (Joe90)
Aside from meeting inspection standards or needing to keep everything original, there is no reason why you cannot remove the cats. The main issue in later models, is the location of the O2 sensor. The '92 O2 sensor is in front of the cats and will therefore not notice any change.
Old Jul 26, 2002 | 01:31 PM
jeffie86/96's Avatar
jeffie86/96
Default Re: Do i need cats (PTz-92-LT1)
I prefer to keep the cats off my car but if there is a small rodent problem then the cats are allowed inside , the only problem if getting the hair vacuumed out. :jester
Old Jul 26, 2002 | 03:10 PM
Mile High
Mile High "91"
where is the o2 sensor on a "91" I was thinking about titling the vette in my moms county because the only inspection is visual and what I mean by visual is no smoke you pass, smoke you fail. I was going to run true dual 3' with no cats and a pair of flowmasters at the back I just didnt know what headders I was going to put on. Oh yea, how much better will my car run with out air emission pump and at the same time do an underdrive pully kit, will I notice a big difference?
Old Jul 27, 2002 | 12:37 AM
dppeaden's Avatar
dppeaden
Yes if you are planning to drive on the street. Or at least a pipe the looks like a Cat. :jester
Old Jul 27, 2002 | 01:51 AM
94-LT1's Avatar
94-LT1
the 92 has oxgen sensors before and after the cat on the right side
To Do i need cats
