What's causing my misfire?
Old Aug 3, 2014 | 06:14 PM
pistolgripump's Avatar
pistolgripump
Default What's causing my misfire?
HISTORY
96 LT4 6spd Corvette. Just finished changing the plugs and wires to MSD 8.5's and NGK BR6ES's gapped to .035 (planning on running a 75 shot). When I screwed in cyl #2 I realized that I cross threaded about 2 threads. Had to rethread the hole. During the process I used plenty of petroleum jelly to catch any metal shavings. The plug is seated well and does not visually leak.
SYMPTOMS
The car starts and runs great. Turns the tires over with a full tank of gas in first gear now from a roll. Sounds like it should. Once it gets above 180F it starts sputtering and misfiring. At about 210F it starts hesitating and misfiring pretty frequently. When you give it past 10% throttle, though, there is absolutely no hesitation or loss in power. At the higher temps timing sounds way off.
I'm thinking I fouled plug number 2? Any other thoughts or ideas? Car has 35k miles and the original optispark, but the lack of misfires during all driving conditions would tell me otherwise. Please help!!!!! I'm desperate......
Old Aug 3, 2014 | 06:22 PM
DanielRicany's Avatar
DanielRicany
Plug a scanner in and check that your CTS temperature is accurate.
Old Aug 3, 2014 | 06:53 PM
pistolgripump
Thank you so very much for your reply! I was wondering if you might elaborate on how that could be causing my trouble? Also, wouldn't the scanner use the voltage output of the sensor to measure temperature (similar to what the gauge cluster is doing)?
Thanks again!!!!!
Old Aug 3, 2014 | 07:05 PM
DanielRicany
Thanks again!!!!!
There is a coolant temperature sensor that the computer uses and a temperature sending unit that the dash uses. The computer will translate the voltage to coolant temperature on the scan tool automatically.
Old Aug 3, 2014 | 07:55 PM
pistolgripump
Ahhh. That makes perfect sense.
I pulled plug 2 and plug 4. Plug 4 looked right. Plug two not so much. Looked extremely lean. Reinstalled the plugs and started the car at 140F and it had all of the hesitations it did at 2xx. I'm confused.
Old Aug 3, 2014 | 08:08 PM
DanielRicany
Okay it looks like it's probably going to be a temperature sensitive injector, or coolant entering the cylinder. Test the ohms on that injector, and tell us what it is. Do this after the engine is warmed up.
Old Aug 3, 2014 | 08:58 PM
pistolgripump
Checked resistance on the CTS. 405 ohms at 165F. Dead on. I'll check the injector real quick. I'll test at the temp its at now, as its misfiring right now.
Old Aug 3, 2014 | 09:05 PM
pistolgripump
14.1-14.3 ohms of resistance on that injector while key is in the ON position but vehicle is off.
Old Aug 3, 2014 | 10:04 PM
DanielRicany
That seems to be okay. That's with it hot right? Next step is to do a hot compression test, and leakdown test if available to you. And also, a coolant system pressure test would help too.
Old Aug 3, 2014 | 10:05 PM
DanielRicany
Actually, get it hot and test for injector pulse on that injector connector before you do the stuff I said in my previous reply.
Old Aug 3, 2014 | 10:28 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yikes. WATCH OUT, OP!
You're problem isn't likely injectors or "Coolant entering the cylinder" Where did THAT one come from??
FAR more likely, the problem is in the ignition system. I see that you changed the wires and plugs. I don't feel that the stripped plug threads would contribute to or influence the symptoms. I'd be more inclined to check/test the distributor, ICM and coil. How many miles on the car? When was the last distributor maintenance/replacement?
When the symptoms occur...when it's missing and hesitating, what does the tach needle do? Stay steady at what seems to be the correct RPM? Or does it flutter/sag or fall out of whack w/the RPM of the engine?
Old Aug 3, 2014 | 10:51 PM
DanielRicany
Gee Tom, I wasn't aware that an ignition misfire would leave the plugs white.
Old Aug 4, 2014 | 08:23 AM
pistolgripump
Car has 35.5k miles and has never had issues or maintenance in regards to the ignition. The tach is calm during sputtering. I reconnected all the boots yesterday. Otispark is dry and the water pump isnt weeping. Car has only seen rain twice and it was last year. I'll try to check the injector pulse tomorrow. Again, I'd like to express my sincere gratitude for everyone's help!!!!!
Old Aug 4, 2014 | 11:36 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Well "gee" not that this is relevant here Daniel, but if there is no spark, what creates the combustion that would color the plug? IOW, how is the plug going to get "colored" any more than another plug, in the absence of combustion? THINK.
As a mechanic with all of your..."experience", what color are the porcelain on most plugs, removed from most EFI vehicles? (Pretty damn white).
Old Aug 4, 2014 | 12:23 PM
ANTI VENOM's Avatar
ANTI VENOM
I would consider working backwards.. ie..put in the old plugs. Did it help? put on the old wires. You didn't change much. I just like to keep it simple. If the old parts don't help then you can at least eliminate the plugs and wires.
I don't know the NGK plug line up. Is the 6 one step colder for nitrous?
Old Aug 4, 2014 | 12:55 PM
Dt86's Avatar
Dt86
With my 86 there is specific routing for the plug wires to prevent misfiring. Since you replaced yours and now have a problem maybe it could be this.
Old Aug 4, 2014 | 01:05 PM
DanielRicany
Tan actually. And with no spark to the cylinder at all, they have turned yellow.
To What's causing my misfire?
Old Aug 4, 2014 | 01:12 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Negative on both counts. Go back to auto skool.
That is one possibility. I would focus my attention on the ignition. I had the same symptoms that you are describing. It was my OPTI and I WAS ABLE TO PROVE IT before spending money to replace it. I'm not saying that it is for sure your opti....I'm saying that it's ignition related, and that a diagnostic process should ensue to determine which component it is.
Old Aug 4, 2014 | 01:48 PM
pistolgripump
:iagree: That is one possibility. I would focus my attention on the ignition. I had the same symptoms that you are describing. It was my OPTI and [URL="http://forums.corvetteforum.com/c4-tech-performance/3020087-92-lt1-gets-warm-then-dies.html"
I WAS ABLE TO PROVE IT[/URL] before spending money to replace it. I'm not saying that it is for sure your opti....I'm saying that it's ignition related, and that a diagnostic process should ensue to determine which component it is.
I'll check for plug spark as well. Attached are plug 2 and plug 4. Remember these plugs have about 75 miles on them.
Plug 2
Plug 4
Old Aug 9, 2014 | 08:52 AM
pistolgripump
OK. Finally had the chance to check spark to #2 and it was fine. What I did notice, though, is that the plug had regapped itself to less than .020.?!?!?!?! Thoughts?
