Spark Plugs
What spark plugs should I get and where can I get them?
Im sure most would suggest replacing the wires w/ it so Ill take suggestions on that also.
-Melt
I would suggest NGK TR55s plugs and some taylor wires.
I just doing mine and it took me about 8 hours to do, grrr. Oh well, I really enjoy the satisfaction of doing something yourself and not having to pay like $300 to $500 for someone else to do it.
You will be sure to see multiple posts from me. I have tons of questions!
So many things to add and no knowledge how to do it! :)
Now where can I purchase the NGK TR55 plugs from?
:eek: :eek: :crazy:
www.speeddemonmotorsports.com
They are a supporting vendor, try the forum mall too.
[Modified by enhance, 8:05 PM 7/26/2002]
Passenger side wires = not too bad, driver side = Oh Boy :eek:
Why do you want to do these things?
I've got the plug change job down to about 2 hours now. 1st time I did it took me almost 4 hours. One thing, you *must* use a good anti-seize compound on the threads of the new plugs. Aluminum heads and all. Lot of guys use the NGK TR55 plugs, I tried them and prefer the factory stock AC 41-906's. I used a copper-based anti-seize compound, make sure whatever you use it conducts electricity so the plugs get a good ground connection, than a little bit of di-electric grease in the plug wire's terminal boot.
Make sure engine is cold, having sat overnight is good.
A shop will want around $235 to do the wires. That's about what Tony McKnight quoted me at his Corvette shop (recommended if you use a local shop). Guy named 'Van' at Northside Chevrolet is a good LT1 wrench, but you have dealership labor rate which is high.
-Melt
[Modified by Lone Ranger, 10:18 PM 7/26/2002]
[Modified by Lone Ranger, 10:27 PM 7/26/2002]
Sounds like the plugs can be done but are a heck of a time to do them!
I want to do change the plugs out, because it doesnt seem like they have ever been changed and it seems like people tell me to change the wires at the sametime I do the plugs.....
I figured this group of people would know best on what to do
Taken two weeks ago @ Wesselman Park
Hey, one thing (important!) a new LT1 owner should know: DON'T HOSE DOWN THE ENGINE TO CLEAN IT! Maybe you already know... Opti-spark distributor sits on front of engine block nestled under the water pump, and it is VERY sensitive to moisture such that if it gets sprayed water can get in and it can permanently screw up the internals of the distributor. In '95 they went to a more robust one and vented it with engine vacuum but they're still best not getting wet if you can help it.
[Modified by Lone Ranger, 10:42 PM 7/26/2002]
I have not seen it, but now that I know what it looks like I am sure I will notice it one of these days.
http://meltingman1.home.insightbb.com/
Pics of my vette when I first got it...Had it about a month. If you have driven past the Gateway computer store, you should have seen it.
Did you buy your 'Vette from the dealer next to Applebees on Morgan Avenue? I thought I saw an Aqua coupe there awhile back... Just wondering.
I was dealing w/ Wright Motors and they purchased the Vette from them cause I had one coming in from a guy that backed out on a deal w/ them.
I got an EXCELLENT trade in on my crappy 'ol Dodge Avenger.
