Tranny fluid leak ! HELP
Old Jul 27, 2002 | 09:29 AM
Sliding's Avatar
Sliding
Default Tranny fluid leak ! HELP
I've noticed a few months ago that tranny fluid started to leak.
Now every time when I go for drive and come home, park the car
over night, in the morning there is some trans. fluid on the floor.
It looks to me that it's leaking more than before.
I've checked trans. fluid level and it's still the same but I really
don't like to see any fluids under my car.
Do You have any experience with this sort of problem?
What are usual soft spots?
:chevy
Old Jul 27, 2002 | 09:51 AM
SlowJoe's Avatar
SlowJoe
Default Re: Tranny fluid leak ! HELP (Sliding)
Easiest/first thing to check is that the pan bolts have not come loose.
Old Jul 27, 2002 | 10:36 AM
Rick86's Avatar
Rick86
Default Re: Tranny fluid leak ! HELP (SlowJoe)
It could leak from front seal, rear seal, pan gasket, gear selector seal, or trans lines. All but the front seal can be repaired with the tranny in place. You need to get the car up in the air wipe everything down and look for the source.
Old Jul 27, 2002 | 10:39 AM
tarheelracer's Avatar
tarheelracer
Default Re: Tranny fluid leak ! HELP (Rick86)
Most likely place for transmission leaks.....pan and bolts, and the transmission lines.
Old Jul 27, 2002 | 08:07 PM
Ramjet's Avatar
Ramjet
Default Re: Tranny fluid leak ! HELP (tarheelracer)
Hey Tarheelracer, nice Tux... :D :D :jester
Old Jul 28, 2002 | 12:31 AM
tarheelracer
Default Re: Tranny fluid leak ! HELP (Ramjet5)
Yeah, that's sharp isn't it? I was way out of my element, It got me a good girl for that date at least.
Old Jul 28, 2002 | 06:48 AM
Sliding's Avatar
Sliding
I've checked and pan bolts were loose.
I've also changed trans. fluid yesterday ( 4.5 quarts ), so I'll see with time
if there will be any more leaks.
I'll change two more times so that all of old stuff will come out.
For now everything seems O.K.
Thanks for help.
:cheers:
To Tranny fluid leak ! HELP
