C4 starting issues
before digging for more obscure problems like VATS. .....
So, the original thought was:
OK, If I'd have thought it through, I'd have also suggested checking for voltage and ground at the switch. So, if you don't mind, crawl back under the dash and back probe the switch connector and check for voltage coming into the switch when the ignition key is turned to start. For this check, use a good ground point, not the other side of the safety switch (don't depress the cluch pedal for this test). If you get 12~14 volts at the safety switch, then it is a good bet that everything down to the switch is behaving correctly (battery, fuses, ignition switch contacts, wiring). Assuming you find voltage, check for low resistance between a good ground point and the other side of the safety switch. Turn the ignition switch to "start" for this test also. Infinite resistance (no evidence of continuity) suggests a problem down stream if the safety switch. Anyhow, let me know what you find and I will look at my 94 FSM when I get home and trace out the whole "start circuit". I think there is probably little or no difference from 94 to 96.
You have a 96?
If so, you can delete that completely, best I know. I have a 95 and Ed H'nstuff......
probably be looking for some VATS options.
Just something to check...
Try holding the key in the ignition switch at different positions to see if the Security lite goes out.
If the ignition lock cylinder is worn, such that the key moves around alot, then time to replace the lock cylinder.
I know there are many threads on here about how to bypass VATS which you could do to isolate the problem.
Good luck.
When you turn the key to ON, the security light should be out providing there is no VATS event.
If there is a VATS event and the key is turned to ON, the security light will light up steady and stay on. If you turn the key to OFF, the security light should go out (which is the beginning of the time to let VATS reset).
If you at that point turn the key back to the ON position in a few seconds (or before VATS resets), the security light will go back on steady and you have started the VATS reset from the beginning again.
Although the FSM says 2 minutes to reset VATS, experience by others show that it can vary. I would definitely give it a good 3 minutes and some say 5, opinions vary.
But my main point is when you have a VATS event and the security light is lit steady with the key to ON, when you turn it off and pull the key out, the security light should go out. If it does not, that sounds like a problem to me and the CCM directly controls VATS and the security light.
Although I agree with cleaning the key pellet and internal contacts of the cylinder, this is a different issue from the information I have explained above. I have found to clean the contacts on the lock cylinder, using a wood Q-tip works best. It is a bit thinner than the regular ones and has a long stick.
thanks to all for your time and advice.
