1989 idle problem
Old Aug 15, 2014 | 03:16 PM
james henry's Avatar
james henry
2nd Gear
Default 1989 idle problem
My autimatic 1989 has a idle problems, where it idles high (15-18 Rpms) in park but once put into gear it drops dramatically until the point of stalling. Any ideas on what it could be?
Old Aug 15, 2014 | 06:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
My first guess would be an IAC problem, possibly combined with a vacuum leak.
Old Aug 15, 2014 | 06:42 PM
playsdixie's Avatar
playsdixie
check timing/ tps/ set min idle....first..check for a vac leak....
Old Aug 15, 2014 | 09:06 PM
WW7's Avatar
WW7
with the guys above... Pull the IAC and clean it with spray cleaner..Pull the bottom plate off the Throttle body and clean all the channels under there with an old tooth brush and cleaner...Then set your minimun idle like suggested if it's still off...Don't forget to check for a vacuum leak.......WW
To 1989 idle problem
