Running Hot at Stop Lights
Old Aug 15, 2014 | 05:26 PM
HuskerTommyG's Avatar
HuskerTommyG
4th Gear
Default Running Hot at Stop Lights
New owner of 90 roadster. Finding when at stop light for any length of time, engine starts running hot. When I get going again, temp goes back to normal. Not using air conditioner because it doesn't work. I had radiator flushed and no help. Does it need some other cooling help?
Old Aug 15, 2014 | 06:04 PM
charliet615's Avatar
charliet615
Tommy, the electric fan comes on around 225 degrees. These cars do run hot so let the car idle and see if the fan comes on. If the ac is not working but hooked up, turn it on to see if the fans come on. Let me know what occurs.. Congrats on being a new owner and welcome to the Forum. There are a lot of Great Guys on here to help you..Charlie
Old Aug 15, 2014 | 06:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Define "normal" temp and how high does it go above that??
Old Aug 15, 2014 | 10:45 PM
Tommycourt's Avatar
Tommycourt
Normal temps for my 88 C-4 vert. in traffic is usually 215-220 and sometimes higher. I live in Az and our elevation is 1760 feet. With the A/C on, I have had my temps up to 238 degrees. Anything under 245 degrees, you should be ok. If it goes over that, shut down and let it cool off. Don't know where you are at, but don't think your temps are as bad as here.
Tommy
Old Aug 16, 2014 | 01:59 AM
cudamax's Avatar
cudamax
Since you just got and don't know. You have to clean out the Fins on the Radiator. The factory decided to use a single/1 core and use many, many more fins per inch than normal to help cool that thing. So that means a lot of smaller places for crap to get stuck from just driving around.
Clean it with a hose and make sure with the water u go back out of the thing. I mean go from the engine side to the front nose, it comes out easier and do the same with the a/c condenser and do it only after watching this video and pulling the top cover off because they also suck up a lot of crap in between the set up.
And if u have the extra cooling fan in front. Try a lower sensor
Maybe the main engine fans Inop? Make sure its coming on
Watch this video and don't ever forget the cooling fan control switch. Its right next to the A/C high side cut off. This little one will save ya a motor and or a tow someday when ur out.
Old Aug 16, 2014 | 10:47 AM
sjarrett71's Avatar
sjarrett71
My engine temp would also creep up while sitting at a stop sign or stop light. I cleaned about 5 pounds of dirt, rocks, grass, and leaves from in between the radiator and A/C condenser, flushed and cleaned my cooling system, added some coolant additive, and now it very rarely ever gets up over 195. I actually had to put it in my garage with no air flow to get it up to a high enough temp to get the fan to turn on so I could make sure it was working.
Old Aug 17, 2014 | 02:44 PM
HuskerTommyG
4th Gear
Thanks for the advice. I'll try and get back to you
Old Aug 17, 2014 | 02:55 PM
HuskerTommyG
4th Gear
Thanks for the advice. I'll check that area.
Old Aug 17, 2014 | 04:43 PM
79C3tnd's Avatar
79C3tnd
A lot of the same information that was already covered in this thread, but check out the sticky at the beginning of the C4/ General Discussion forum here...
To Running Hot at Stop Lights
