Cam choice help please
Old Aug 18, 2014 | 08:03 PM
ttt123's Avatar
ttt123
Default Cam choice help please
Can anyone offer a sugestion for a cam kit? Browsing threads and ebay with all the choices... Its just to easy to get lost in the info. If anyone has a suggestion it would be greatly appreciated. Below is what i have now and can adjust for cam as needed.
1994 coupe with lt1... All stock as of right now.
B&m shift kit and 3:54 gears along with new suspension are being done right now.
I am pulling the motor and can get a torque converter to match with the best cam kit sugested the heads will be opened up and ported along with intake gasket match..... Please help
Old Aug 18, 2014 | 08:16 PM
cv67's Avatar
cv67
St. Jude Donor '05
Do you have to pass emissions?
THeres many choices out there, the LT4 hotcam is a popular choice just use better springs
Old Aug 18, 2014 | 08:18 PM
ttt123's Avatar
ttt123
Im in michigan so no emissions. It is a daily driver and i forgot to mention i have a set of long tube header to go with it all as well. I just want it to be mean dd without having to get to crazy.
Old Aug 19, 2014 | 08:04 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Goto the CompCams website and use their cam recommendation tool.
Worked good for me
Old Aug 20, 2014 | 11:18 AM
ttt123's Avatar
ttt123
Worked good for me
So i talked to comp-cams and they suggested "07-467-8"
Anybody have any thoughts on that cam choice?
Old Aug 20, 2014 | 11:23 AM
cv67's Avatar
cv67
St. Jude Donor '05
Yeah, too big.
Old Aug 20, 2014 | 11:34 AM
ttt123's Avatar
ttt123
Yeah, too big.
Awwww!!! Lol i just want a nice ride .. Anyone have some suggestions. I think i listed all my mods that ill be making. I can change things up if needed. Any more info needed? Ease help this cam newbie out.
Old Aug 20, 2014 | 11:38 AM
vader86's Avatar
vader86
I see nothing about an end goal here, we need to know that. We also need to know what else you are doing to the motor.
Old Aug 20, 2014 | 11:45 AM
ttt123's Avatar
ttt123
3:54 gears
2500-2800 stall and b&m shift kit
1.6 roller rockers
Ported heads and intaked
Pcm tube
Obx long tube headers.
Thats what i have so far. End goal is just a fun daily driver. I live in the country and have a 25minute drive to work and thats all this car will ever see. I go through two stop lights.
Old Aug 20, 2014 | 11:51 AM
ttt123's Avatar
ttt123
3:54 gears
1.6 roller rockers
Pcm tube
Old Aug 20, 2014 | 11:54 AM
vader86's Avatar
vader86
LT4 hotcam kit is fine, but I'd go with CC503.
Old Aug 20, 2014 | 12:19 PM
ttt123's Avatar
ttt123
Sorry for the double post guys.
So searched and read comments on the cc503 and pretty much a lots of people lime it who have it. Do i need to do anything to use this cam or can i basicaly put it in with my 1.6 roller rockers and beehive springs.
Thanks for the suggestion vader.
Old Aug 20, 2014 | 04:24 PM
STL94LT1's Avatar
STL94LT1
Old Aug 20, 2014 | 04:50 PM
ttt123's Avatar
ttt123
is this the kit?
http://www.jegs.com/i/GM+Performance...80002/10002/-1
Old Aug 24, 2014 | 10:29 AM
C4in mesa's Avatar
C4in mesa
If you are going to pull the motor then spend the additional money and stroke it. At least think about it. Weigh the BENEFITS and the cost. At the very minimum an additional 50 horsepower to your car. All the other things you are doing it will cap it off and you will have a real beast ! 400HP to the rear wheels.
Old Aug 24, 2014 | 03:48 PM
ttt123's Avatar
ttt123
Thanks for the input... I have thought about it and i still have some time to decide. Ive just started pulling it and i have all winter before i put it back on the road. I do want it to be very streetable and ive never owned a 383 so im not well informed on there road manners
Old Aug 24, 2014 | 04:19 PM
C4in mesa's Avatar
C4in mesa
My buddy had a 600rwhp 1996 C4 and it was very mello until you stepped in the gas pedal. Then it unleashed massive power immediately. In other words the car will be a kitty cat until you release the tiger !
To Cam choice help please
Old Aug 24, 2014 | 09:08 PM
ttt123's Avatar
ttt123
What kind of mods would have to acompany a stromer kit? Other then a tune, could i pretty much keep everything else stock? Or is there an optimum cam that would work well with a stroker. Ive had 800hp camaros and im just not looming for a pavement rumbler... Just a nice fun street car. Ease offer some insight guys
Old Aug 25, 2014 | 11:45 AM
vader86's Avatar
vader86
If you enlarged the engine you would only need to worry about changes for the camshaft you're adding (springs, etc.), it wouldn't require anything else than what you have planned above.
Hotcam or CC503 will work just fine with the stroked engine, you could actually go a touch bigger than that and keep just fine street manners.
Old Aug 25, 2014 | 01:38 PM
ttt123's Avatar
ttt123
Thanks for the input guys.
