Rasping and Squeaking Engine Noise
Old Aug 22, 2014 | 01:03 AM
C4ProjectCar's Avatar
C4ProjectCar
Default Rasping and Squeaking Engine Noise
While taking my car for a test drive after replacing my main and rod bearings and installing a HV oil pump because of low pressure, I noticed a rapid squeaking noise. It seemed to be more noticeable at lower speeds. I thought it was just the serpentine belt. When I brought it back and ran it in the garage to find the squeak, I noticed a rasping noise. Fairly rapid, about 5 times per second (if I remember right), it seemed to be coming from the distributor when I listened from the passenger side. When I moved to the driver's side, it seemed to be coming about from the middle of the head on that side. Can anyone venture a guess what it could be? Here's a video to help:
Old Aug 22, 2014 | 12:50 PM
C4ProjectCar
Anyone?
Today I plan to run it until it makes the noise, then turn it off, take off the serpentine belt, and restart it to see if it's one of the accessories making the noise.
Old Aug 22, 2014 | 01:51 PM
charliet615's Avatar
charliet615
That is the best plan of action for now...You did a lot of work so far. I hope it's nothing serious....
Old Aug 22, 2014 | 01:59 PM
C4ProjectCar
Thanks Charlie!
To Rasping and Squeaking Engine Noise
