Interior lights
Old Jul 28, 2002 | 01:52 AM
Racer1x's Avatar
Racer1x
Default Interior lights
My interior lights dont work, what could be wrong? :confused:
Old Jul 28, 2002 | 02:01 AM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: Interior lights (Racer1x)
1) Stuck door pin switch.
2) Blown fuse, CTSY1 and CTSY2 in the fuse block
Old Jul 28, 2002 | 02:46 AM
jfb's Avatar
jfb
3) Burned out light bulbs.
[Modified by jfb, 12:47 AM 7/28/2002]
Old Jul 28, 2002 | 02:49 AM
Racer1x's Avatar
Racer1x
Default Re: Interior lights (jfb)
They work with the dash switch.If I pop the hatch the ones in the back work. :crazy:
Old Jul 28, 2002 | 02:56 AM
Wadoka's Avatar
Wadoka
Okay, your driver's side door pin switch is probably stuck pushed in.
Turn the key to 'run' and turn the radio on. The antenna mast goes up. Turn the key to 'off'. The radio is still playing. Open the door. If the radio keeps playing and the antenna mast stays up, it's almost definitely a stuck pin switch. Pop it back out and think about spending $7 for a new switch. Easy swap.
Old Jul 28, 2002 | 03:11 AM
Racer1x's Avatar
Racer1x
Default Re: Interior lights (Matt Black)
Ok just went out and checked that,radio turns off when I open either door but no lights.
To Interior lights
