which engine to build?
Old Jul 28, 2002 | 02:08 AM
kawboy5792's Avatar
kawboy5792
Default which engine to build?
i wanna turn my 94 into a streetable beast....which should i do (serious answers guys)? feel free to add other categories
Old Jul 28, 2002 | 03:55 AM
pablocruise's Avatar
pablocruise
Default Re: which engine to build? (kawboy5792)
will those blocks line up to the bellhousing? I have never known about that.
I vote for as much CID as you can get :D
Old Jul 28, 2002 | 11:58 AM
TheCorvetteKid's Avatar
TheCorvetteKid
Default Re: which engine to build? (89 Paul in Cal)
If you're running a ZF6 speed, either of the first two options would be good. The third engine will prove a little more work mating up the clutch/flywheel 'cause of the different bolt patter on the back of the crank due to the 2-piece rear main seal on the 400 block. Still 'do'able...just more work.
Personally, I'd build the 396 LT1. Lots of people have 383s. But a 396 SBC isn't quite as common, and has a nostalgic feel too.
Just my $0.02.
Good luck with the decision.
[Modified by TheCorvetteKid, 3:59 PM 7/28/2002]
Old Jul 29, 2002 | 03:13 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
383 stroker! :yesnod: :D
Old Aug 1, 2002 | 08:49 PM
YellowFvr's Avatar
YellowFvr
Default Re: which engine to build? (yoslambo1@cs.com)
any realistic estimate for a 383 or 396 stroker with forged rods/pistons? how much to have a mechanic swap the engines?
Old Aug 1, 2002 | 11:18 PM
96LT1's Avatar
96LT1
Default Re: which engine to build? (YellowFvr)
Start off at about $8K and work up towards $14K. Labor for a turn key system should run between $1K & $2K depending on shops, labor rates, etc.
The upper end should include the entire package;
cam, rods, pistons, rings, seals, headers, heads (P&P), intake, injectors, TB, fuel pump, oil pan, oil pump, MSD ignition, etc, etc...
Old Aug 4, 2002 | 11:21 AM
yoslambo1@cs.com
i paid about $700.00
To which engine to build?
