Hack Hypertech PPIII?
Old Jul 28, 2002 | 12:28 PM
Lone Ranger's Avatar
Lone Ranger
Default Hack Hypertech PPIII?
Would it be possible to hack the fan activation temp settings in a Hypertech Power Programmer III to insert your own choices?
Old Sep 9, 2002 | 11:44 PM
Ericthewolf's Avatar
Ericthewolf
Default Re: Hack Hypertech PPIII? (Lone Ranger)
Yes just use CATS tuner program to save the hypertech program and the stock once you removed the hypertech (sell it the hypertech) then just use the cats programs to load/change any setting you want.. reselling the hypertech will pay for the cats software..Much more technical than the hypertech but if you are computer literate you should be able to figure it out.
Old Sep 10, 2002 | 08:06 AM
Lone Ranger
Default Re: Hack Hypertech PPIII? (Ericthewolf)
I thought LT1EDIT was the only program you could use on a 94 - 96 LT1? If CATS will work, where can it be found to buy? I realize I will need a custom cable...
Old Sep 10, 2002 | 10:00 AM
ZylaRace's Avatar
ZylaRace
http://www.tunercat.com
You will need to unsolder the FLASH chip, save it as your base CAT code, edit it, then reprogram your FLASH.
Old Sep 10, 2002 | 12:22 PM
RadPolo96's Avatar
RadPolo96
Default Re: Hack Hypertech PPIII? (ZylaRace)
To bad they dont offer it for my Year :rolleyes:
Old Sep 10, 2002 | 03:12 PM
Lone Ranger
:eek: :eek: I'm too chicken to try and take a solder tool to my ECM. Looks like I'll be trying LT1EDIT. Thanks, though, for the advice on Tunercat. I'd prefer to access the PROM through the ALDL under the dash. I though Tunercat did it that way like LT1EDIT.
Old Sep 11, 2002 | 02:18 AM
drive it's Avatar
drive it
Well...it does access thru the aldl on your year....you need the akm cable that has the obd2 plug on it. The tunercat comes with the "connection" software along with the tdf file! (And a lot better price than lt1edit!)
Now I'm just hoping/waiting for tunercat to come out with odb2!? Any news on that?
Old Sep 11, 2002 | 12:48 PM
ZylaRace's Avatar
ZylaRace
Default Re: Hack Hypertech PPIII? (drive it)
TC ODBII,
Every quarter, they tell me next quarter,.......
Last time they told me,... end O year
[Modified by ZylaRace, 10:49 AM 9/11/2002]
To Hack Hypertech PPIII?
