Harmonic Balancer
Old Jul 28, 2002 | 03:23 PM
Racer1x's Avatar
Racer1x
Default Harmonic Balancer
Is it supposed to run true? Mine wobbles just a little bit. Rubber looks a bit cracked as well is this normal?
Old Jul 28, 2002 | 03:53 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Harmonic Balancer (Racer1x)
It should run true.
A wobble with cracked rubber could be a sign that it needs (or will soon) replacement.
Old Jul 28, 2002 | 04:02 PM
Hendej's Avatar
Hendej
If it's like the L98 HB, the outside part will be sliding back into the timing cover, and the timing mark will be moving back. Mine was adding an extra 13 degrees base timing when I finally replaced it.
To Harmonic Balancer
