AIR pump/cat delete
Old Aug 29, 2014 | 03:33 PM
L98auto's Avatar
L98auto
Default AIR pump/cat delete
I recently deleted my main cat on my '86. Can I simply plug the hose coming off the AIR pump that leads to the cat? I can't swing an AIR pump delete pulley at the moment. I don't however, want to somehow lockup or damage the AIR pump by plugging the hose. Thanks.
Old Aug 29, 2014 | 04:31 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I don't think plugging any of the AIR pipes/hoses is a good idea.
Old Aug 29, 2014 | 09:57 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Just leave that end of the air pump pipe open. It won't hurt anything at all.
Old Sep 1, 2014 | 10:45 PM
Z51breeder's Avatar
Z51breeder
You need a new chip burned now to delete it out of the chip, You just threw off the Air/fuel mixture.
Old Sep 2, 2014 | 01:50 AM
Cliff Harris's Avatar
Cliff Harris
The default mode for the A.I.R. switch solenoid is pumping air into the rear cat, so you don't want to plug it. It probably spends about 90% of its time in this mode.
The ECM adds a bias to the O2 sensor reading when the A.I.R. switch solenoid is pumping air into the exhaust manifolds. This doesn't happen very often (mainly while decelerating), so I don't think it will be a problem.
Old Sep 2, 2014 | 09:54 AM
FOURSPEEDVETTE
Wrong. The air pump feeding the catalytic convertor has nothing at all to do with the fuel/air intake mixture for the engine. That air pump only feeds air to the catalytic convertor. The exhaust in other words. Not the engine. The pump and lines can be left in or taken out if the cat is removed. Leaving the pump and lines in won't hurt anything. I've been running mine without the cat for years and my pump and lines are still in place. It runs perfectly.
To AIR pump/cat delete
