Carb conversion
Old Sep 2, 2014 | 08:43 AM
  #41
Chevrolet12's Avatar
Chevrolet12
That's the only one I have
Old Sep 2, 2014 | 10:35 AM
  #42
Chevrolet12
Isn't there a way to do it through the Aldl connector?
Old Sep 2, 2014 | 07:15 PM
  #43
confab's Avatar
confab
This is all I can find..
Old Sep 2, 2014 | 07:20 PM
  #44
confab's Avatar
confab
And again, you ground wire 422 with a switch, and it comes on.
You can wire the 4th gear switch (Which I don't see?) inline there also.
Old Sep 2, 2014 | 10:17 PM
  #45
Chevrolet12
If I am reading it correct it looks like 422 goes to the Aldl connector pin f and pin a is a ground and should activate it then. Right?
Old Oct 10, 2014 | 01:25 PM
  #46
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by Tom400CFI
I removed the regulator housing/assy from the TB.
Then I cut the potion off that goes to the injector, drilled and tapped the orifice that normally goes to the injector, for a 1/8" NPT fitting, and threaded in a nipple. That is where you connect your line from tank/pump.
In the pic above, see the part of the casting that is raised and has a "round" spot? I drilled and tapped that for a 1/8" NPT, also, and threaded in a nipple...that is your return to tank.
On the other side, where the tank return port originally was, I threaded that and installed a NPT plug. Could have put the return there instead and saved a step.
I simply hooked the feed hose from the fuel pump to the "inlet", then the return hose to the "outlet". Now everything between the fuel pump and the regulator is going to be regulator set pressure. Install a "T" in that line before the regulator, and run that line to your carb. Carb will always see your set pressure. Turn the adjusting screw all the way in to drop the pressure all the way down which should get you to ~7-8 PSI. If that is too much, cut 1 coil off the spring in the regulator, and then readjust to suit your desired pressure.
I did ^that about 5 years ago and it's still running great w/a Q-Jet carb., on the stock in-tank electric fuel pump.
Originally Posted by Chevrolet12
Do you have a picture of what it looks like finished?
Well, I don't work at the place I did that for any longer, but since I am still friends w/the folks who do work there....I'll see if they can snap a pic of it and text it to me. It isn't pretty, but it works. I could be made to look nice if that were important; fab a nice little bracket, polish it and clear coat it...it could look cool.
Took awhile, but here is the pic. I did say that it isn't pretty!, plus it's dirty/muddy in this Jeep. In this pic, the regulator is facing the opposite direction than the one pictured above...
