ALDLDroid Info?
If you have it, do you like it more than a scanner of a comparable price?
Does it have all the functionality a scanner does?
I heard something mentioned about the bluetooth plug needing a power source. Would I need to open up my dash and splice in a wire for the plug?
The app description mentions that it can be used for tuning. I'm thinking about tuning my car myself instead of paying someone else. It sounds like the learning curve is brutal, but doable, and I'm always up for a challenge. However, I'm entirely new to this so I don't know what would be required. Is ALDLDroid and the cable sufficient equipment to tune it, or would I need to buy something else?
EDIT: It looks like I might need a chip burner too? Perhaps a chip as well? Here are the two things Moates said I would need:
https://www.moates.net/burn2-chip-pr...chip-p-39.html (it actually said BURN1 but I believe BURN2 has replaced it)
https://www.moates.net/c2-sst-27sf512-chip-p-39.html
Yes see above, I have never used a scanner.. I used laptop programs int he past and currently, ALDLDroid is nice for tablet portability
so fro this, Yes you CAN tune from the program, but I would also look at TunerPro for the PC as well, ALDL accepts the TunerPro files which makes it that much easier to bounce between the 2 if needed.. I do a lot of the Chip burning and programming on the PC and datalogging on the ALDLDroid. If I had an ostrich or the APU1 I could burn as I go.
The Moates Burn1 ( and 2) are both great, I have the Burn1 and really like it.
The interface is great and very customizable, the datalogging works just fine and the developer of the app very helpful too. Me personally I make sure of having the car running and holding my phone connected monitoring its readings wall inspecting other elements of the car.
I have the 1320 bluetooth aldl port, its about the size of a radar detector and needs a power supply, the cord is pretty long and my plan is to run the cord backwards and mount everything under the dash and out of viewing range.
So it does take a little work to be both wireless and visually wireless
I believe the one form Red Devil River uses 12v power from the ALDL plug itself, so no issues there (you can also get it to connect to the cigarette socket too)
I should be able to use the bluetooth ALDL plug with TunerPro, provided I have a bluetooth adapter on my computer, right?
And to clarify, you use TunerPro (or ALDLDroid) in conjunction with BURN1/2 to tune?
Thanks for your opinion of the app. That's what I seem to be hearing across the board, so it sounds like a good buy.
Mounting the bluetooth receiver out of sight sounds like a good idea. It would be nice to be able to pull up ECM data at any time.
I'm still trying to figure this out - so you either can use BURN1/2 to create a new chip which you then piggyback somehow on the ECM, or you can use Ostrich to change the ECM itself?
I have a permanent install so I use my USB cable for datalogging
So there is a GM Adapter Moates sells, you use that and put a burnt chip in it that you made with the BURN2 OR you connect the ribbon cable of the Ostrich to it and run the Custom file out of the Ostrich.. I would suggest the Ostrich for short term.. burn a chip if you will be leaving it a lone for a bit.
Do you have to buy a new chip each time you burn it, or can you re-burn the same chip?
That setup is pretty sweet. I like it. How do you control the stereo? Do you just play music that's stored on your tablet?
Well, my friend used it forever and the BIN file is not permanently stored.. so he ended up with issues.. it is not recommended for long term use (if no changes are made)
If you buy the ones you posted they are good for 10000+ reprograms so you will be fine with one
The adapter I mentioned:
http://www.moates.net/g1-memory-adap....html?cPath=64
My stereo/tablet project:
https://www.corvetteforum.com/forums...n-1990-c4.html
I'll probably just end up going with burning a new chip. How hard is it to modify the tune on a chip that's already installed?
Here's what I'm planning on needing:
ALDLDroid - $20
Bluetooth adapter - $80
Chip - $5
Chip adapter - $35
BURN2 - $85
Sound about right?
Buy some EPROMs and program away. I got 5 27C128s on eBay for future use...
You will need an ultraviolet eraser to erase the EPROMs. I did some investigation on that and unfortunately UV LEDs don't put out the correct frequency of light. You need an eraser that has UV fluorescent tubes.
A friend of mine upgraded his L98 to 383 cubic inches. He told me he went through 29 iterations on the programming to get it to run the way he wanted it to run. That's why you need an eraser -- you'll be using it a lot. Same rationale for having multiple EPROMs.
I admittedly went into this project knowing practically nothing about working on a car so I make sure to do tons of research ahead of time. Do you have any particular resources you'd suggest?
Wow, UV light? That's sure odd. I'll track one down I guess.
The wireless functionality was the main reason I bought mine. That way, you can install a permanent display showing live information from the ALDL data stream. It looks pretty cool, but it's useful too if you can interpret the data on-the-fly. Like everyone else has said, research will go a long way towards making things easier. The learning curve is kind of steep at first, but if you're the kind of person that's generally thirsty for knowledge, it's probably going to be worth it, especially if you plan on keeping the car indefinitely.
A lot of scanners under $100 are going lack some higher-end features, but it's mostly OBD2 stuff anyway and won't do you much good on anything older than a '94-95. I haven't explored the tuning functionality of ALDLdroid, so I'm not sure if there's any limitations in that regard. I generally use C.A.T.S. Tuner (Tunercat) for offline PROM tuning.
The only thing you might want a traditional scanner for is to read trouble codes off the ECM, as this is something ALDLdroid doesn't do. I have a '93, so I'm not sure if you can use the paperclip method to pull codes off a '90.
As far as the adapter goes, it is very possible that you'll have to wire a switched 12v circuit to it using the terminal lead that Timm sends you with the adapter. It's hard to say, because I don't know what the ALDL pinout on the '90 looks like. Maybe it's the same as the '93, but I'm not sure. I think the adapter comes pre-wired to accept power on pins G or L, so you'll have to look at the ALDL pinout for your year and see if either of those 2 pins will work. I know that on the '93, neither of them do. I had to have Timm re-wire mine to accept power on pin D, as it's one of the only pins not being used for something else. If you do need the adapter wired to accept power from a different pin, then be sure to let Timm know before you buy it, or you may end up having to ship it back so he can fix it. Ask me how I know.
The purpose of this car is for me to learn as much as possible, so it sounds like this app is just what I'm looking for.
I can pull the codes with the whole "jump pins A and B, then watch the speedometer" routine, so I don't need a scanner for that.
I'll check to see if it has power on one of those pins. If not, I'll work it out like you did. Thanks for the heads-up.
Like they say, lessons learned the hard way... I got my share of those too.
I've got the ALDL Bluetooth adapter from 1320 Electronics. It powers off the cigarette lighter, or if you email them they can power it from any pin you want on the ALDL connector.
ALDLDroid is worth every penny. I've never used the programming features. I just log and review the logs later.
Wow, ALDLDroid sure gets glowing reviews! I'm definitely going to get it.
http://www.moates.net/c2-sst-27sf512-chip-p-39.html
There is also the atmel AT29C256 I think. Try looking for those on ebay. People over there are yanking them out of old computers and reselling. Just verify by looking at the data sheet for 27C256 (what I think you have for an EPROM) versus AT29C256.
Moates BURN2 programmer looks to do both.
Thanks for correcting me.
I'll check out that other chip too.
EDIT: I checked the FSM, and it describes pin G as "CCM Diagnostic", so I suspect "12v Fuel Pump Test" is for a different year. Nonetheless, there is still a 12v current from that to ground. Pins D and E are empty, so if pin G can't be used I guess I'll have to wire one of those for 12v. I'm hoping I will be able to use pin G so I won't have to.
