Died and will not start
Old Sep 12, 2014 | 02:07 PM
  #81
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by Rik O'Shay
With the ECM pulled in or unplugged, the pink/black injector wires are showing 8 ohms at every injector, and this with the battery connected or disconnected completely.
With the battery connected, ECM disconnected anf the Key ON, fuel pressure zero - the pump never comes on.
O.K. Did you check the resistance to ground, on the blue and green wires, w/the ECM disconnect? I didn't see that done.
W/the ECM disconnected, you can get the fuel pump to run by installing a jumper wired in place of the fuel pump relay. Or you could charge the line w/the injector fuse pulled, then disconnect the ECM, install the injector fuses and watch your gauge...
Old Sep 12, 2014 | 03:09 PM
  #82
Rik O'Shay's Avatar
Rik O'Shay
Yes, neither the blue nor green injector ground wires were shorted to ground with the ECM installed or removed.
I will try the 2nd way as I'm not sure where the fuel relay is.
I have a reman'd ECM on hand....
Old Sep 12, 2014 | 03:24 PM
  #83
Rik O'Shay's Avatar
Rik O'Shay
Ok, I ran the fuel pressure up with the ECM installed, injector fuses pulled, key ON
- turned the key OFF
- disconnected the battery (very important to do this before you remove the ECM)
- removed the ECM
- reconnected the battery-
- connected a fuel injector connector on each bank
- installed the injector fuses
- turned the key to ON
The fuel pressure did not drop ie: the injectors did not get erroneous power to them from another source.
I'm swapping the Eprom and going for it!
Old Sep 12, 2014 | 03:33 PM
  #84
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
10-4. I think I would too. At this point, it seems you have done a solid job of proving that the ECM is at fault.
*A test of the harness seems to show that the harness is good
*A test of the fuel pressure drop seems to prove that only the ECM is causing your pressure drop (injectors to open).
Looking forward to hearing the outcome.
Old Sep 12, 2014 | 03:48 PM
  #85
Rik O'Shay's Avatar
Rik O'Shay
Eprom swapped, ECM plugged in & everything connected.....
We have steady fuel pressure!
Old Sep 12, 2014 | 04:10 PM
  #86
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
HOT DAMN.....II
Once you get the cylinders cleared and then the engine started, warm it up, then change the oil!
Old Sep 12, 2014 | 04:47 PM
  #87
Rik O'Shay's Avatar
Rik O'Shay
Who hoo!
It started right up!
It is smoking like crazy though as I believe oil & fuel went out through the exhaust and it is literally dripping from the mufflers.
So I need to idle it wor a bit, change the oil & then take it out onto the freeway to burn off the junk in the pipes.
Old Sep 12, 2014 | 05:35 PM
  #88
Rik O'Shay's Avatar
Rik O'Shay
Thanks to everyone but especially Tom- I really appreciate the advice & good guidance!
Old Sep 13, 2014 | 07:51 PM
  #89
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Anytime! I stoked for you that it's fixed, and that you worked through it all the way. Well done!
