L98 engine squeaking noise
Old Sep 4, 2014 | 06:54 PM
dm_c4's Avatar
dm_c4
Default L98 engine squeaking noise
Hi guys,
my L98 engine has a squeaking noise shortly after starting the engine.
Please see this video - I hope the sound can give a little impression of the noise: http://www.myvideo.de/watch/9793138
(you can hear it best from ~1:00 min on)
As far as I can say it does not come from the belt or a tensioner. But it is hard to say. It seems to me that it comes somewhere under the plenum or the ignition distributor. But this may deceive.
Does anyone have an idea where the noise may come from or how I can identify it best?
Thanks so much!
Mike
Old Sep 4, 2014 | 07:31 PM
DUB's Avatar
DUB
First off...it seems like the idle is quite high. What is the engine idling at??? Just curious.
I hear a noise...but I would say...when the noise is there. Shut off the engine and then re-start it to make sure it is still there.....then shut off the engine and remove the serpentine belt and then crank the engine again and see if it is still there. IF it is...shut off the engine and re-install the serpentine belt.
Then...start the engine again....and I have a stethoscope and listen with the tube for the noise. If you do not have a stethoscope...you can use a section of rubber hose/tubing and put it to your ear CAREFULLY and begin putting the other open end in the engine area until you can find it.
DUB
Old Sep 4, 2014 | 07:43 PM
Mike1985's Avatar
Mike1985
I also have this same problem, always just figured it was the belt..
Old Sep 4, 2014 | 07:48 PM
barrypaul2005's Avatar
barrypaul2005
Looks just like my '89 stock auto coup.
The squealing does sound similar to my engine, mine is like a little bird chirping when idling.
I was hoping that would go away on mine after I just did a bunch of work - but today was the first day I got my car running and that squealing is still there. The (rotating) items I can rule out, at least on my car is:
engine (just put a new ZZ4 short block on)
tensioner assembly (new)
power steering pump (new)
oil pump (new)
water pump (new)
timing chain (new)
only things that I didn't change out that rotate is the air pump (original) and alternator (relatively new). I think that's about everything that rotates.
It seems like the sound comes from below the engine somewhere like yours. I just got mine running and I'll be checking with my stethoscope and with and without serp belt on.
Let us know if you find anything - sure would be helpful for some of us. Hopefully someone will identify this noise.
I'll post back when I can check mine out shortly.
Old Sep 4, 2014 | 07:51 PM
dm_c4's Avatar
dm_c4
Ok thank you guys. So you mean I should take off or losen the belt and then start up the engine? Sounds like a good idea to if it is the cause of the noise.
And running the engine without the belt does NOT do any damage?
@DUB: about the idling rpm I can tell you tomorrow. I have a look.
Old Sep 4, 2014 | 08:54 PM
HlhnEast's Avatar
HlhnEast
The AIR pump and tensioner are two places I would look. As far as running the engine without the belt, no, it wont hurt anything but only run it for a little bit as you have no water circulating or recharge going to the battery. As stated if it doesnt squeak cut it off and put the belt back on. Well, spin each accessory and see if you feel any roughness first.
Old Sep 4, 2014 | 09:00 PM
dm_c4's Avatar
dm_c4
Ok thanks! I will try it tomorrow and then give a status on it.
Old Sep 5, 2014 | 02:23 AM
Cliff Harris's Avatar
Cliff Harris
The water pump will not be rotating, so don't run the engine for more than a minute. It's best to do this test when the coolant is cold.
Old Sep 5, 2014 | 06:43 PM
DUB's Avatar
DUB
It does not matter when you do this. IF the engine is HOT and the noise is there....take the belt off and crank it and see if the noise goes away. I am NOT saying drive for hours...ALL you are doing is seeing if the noise went away...when you knew it was there 30 seconds ago when the belt was on the engine.
All you need to do is rotate the belt tensioner and remove the belt completely.
DUB
Old Sep 7, 2014 | 10:56 AM
dm_c4's Avatar
dm_c4
Ok today I removed the belt and found the air pump squeaking when turning it -> http://www.myvideo.de/watch/9795326/c4
Everything else seems to be ok.
So I guess it's coming from the pump. Do I get this fixed without installing a new pump?
Old Sep 7, 2014 | 11:43 AM
John A. Marker's Avatar
John A. Marker
Unless you can pull it apart and install new bearing or can find a shop in Germany that can do this....your going to need a new pump.
Old Sep 7, 2014 | 05:51 PM
DUB's Avatar
DUB
Just be careful when you separate it. Sometimes that can be very hard to do and you can break the housing due to build-up inside. Could be the vanes also...I have seen this before on some cars when I opened them up.
DUB
Old Jul 1, 2019 | 12:08 PM
John Duffield's Avatar
John Duffield
1st Gear
Default Zz4 squealing just went through this with mine plastic plug passenger side valve to
Hi guys,
Thanks so much!
Mike
Duffers @mtsu.net
To L98 engine squeaking noise
