Sending Unit issues
Old Sep 6, 2014 | 01:59 PM
qwiketz's Avatar
qwiketz
Default Sending Unit issues
Hi guys. So I have 2 sending units. One of them is in good condition and when I install it, the pump works fine. For whatever reason on the 2nd one, it is intermittent. I checked the voltage at the wiring harness to the pump prior to install. After install, nothing. Fuel pressure is at 0 at the rail. It did prime after key on, but afterward nothing. The car started, run for about 2 second good, then proceeded to die from no fuel.
Upon inspection, I'm seeing some burn on the harness where it meets the metal part that bolts to the car. I am running a large pump in tank (walbro 465).
My question is, can I buy upgraded, thicker wiring to replace the stock stuff? I bought a racetronix harness but forgot to ask about sending unit upgrades. Here are two pics:
Old Sep 6, 2014 | 02:01 PM
qwiketz's Avatar
qwiketz
I should also add that the other sending unit I have is a zr1 unit so it's not going to work as well with my 465 pump. I'd rather not butcher it.
Old Sep 6, 2014 | 02:09 PM
WVZR-1's Avatar
WVZR-1
If the other (intermittent) is a ZR-1 sending unit then it will have provisions for the second pump and it's wired differently. A ZR-1 initially supplies voltage to both pumps and then switches to primary pump only until the second is called upon for required performance.
You could likely rewire for use in an L98/LT application but I don't know why you would want to. I don't believe I'd mess with/butcher the ZR-1 sender.
You can certainly rewire either of them and it's actually not particularly difficult. Some pump packages from Racetronics and others comes with what they want you to use for a harness.
Old Sep 6, 2014 | 02:11 PM
qwiketz's Avatar
qwiketz
actually, it's the lt1 sending unit that is intermittent. The zr1 unit was modified to run both pumps at once.
Old Sep 6, 2014 | 04:27 PM
qwiketz's Avatar
qwiketz
did some more testing and it's definitely the wiring on the lt1 unit. I'm going to swap some of the wiring; the zr1 unit is in great condition compared to my beatup lt1 unit.
edit, upon disassembly, the ground is different on the two. It could be done but I'll contact racetronix and see if they have anything to work with my situation. If not, I'll buy a used one.
edit, edit.... I'm modifying the zr1 unit to work. I like it having two pins for the hot instead of one. I'm running a walbro 465 pump which is putting probably about 17-18 amps through the pin so I'll set it up to use both and then feed the positive wire to the pump. I removed the plastic part of the sending unit for the 2 pumps, and will attach the pump to the metal frame using clamps. I'll post some pics tomorrow.
Old Sep 7, 2014 | 03:29 PM
qwiketz's Avatar
qwiketz
well, I went ahead and butchered the zr1 sending unit. I like this one because the current for the pump is passed through the bulkhead using two connectors instead of one. I'm not sure if I was running too much power through the old one or if something else caused it to fail, but it looks dead. Here's pics of the dead one and the new one and my final modified zr1 sending unit prior to install.
To Sending Unit issues
