cross threaded spark plug
Old Sep 7, 2014 | 10:41 PM
LANDSHARK1's Avatar
LANDSHARK1
Very odd about that bent electrode, especially since you gapped it prior to install.
BTW, for what it's worth, although I've never done it...yet, I have heard of people putting grease or vaseline on a thread chaser to prevent fresh shavings from falling into the combustion chamber when chasing a spark plug thread.
Old Sep 8, 2014 | 06:52 PM
Impala Balko's Avatar
Impala Balko
The only thing I can think of is maybe it got crooked enough where it put enough pressure on the ground strap to bend it.
Old Sep 9, 2014 | 04:01 PM
htrdbmr's Avatar
htrdbmr
Can you look in the hole and see that it's clear? Don't know what could be in there, but you never know.
Old Sep 9, 2014 | 04:42 PM
383vett's Avatar
383vett
Is that like turning straight plug heads into angle plug?
Old Sep 9, 2014 | 09:40 PM
Impala Balko
I looked using a mirror and everything looks clear the threads just look a little beat up
Old Sep 9, 2014 | 09:44 PM
Impala Balko
No I was referring to the thread cross threading.
Old Sep 10, 2014 | 06:29 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That along with the fact that the plug only went in ~1/2 way sounds very promising that it will respond well to a careful chase.
BTW, what year Vette, engine, heads, exhaust???
Old Sep 10, 2014 | 08:14 PM
Impala Balko
94 LT1 Base Coupe 6-spd stock engine, stock heads, with long tube headers, and remote mounted 76mm turbo.
Old Sep 10, 2014 | 09:24 PM
solaris_vii's Avatar
solaris_vii
i just used a spark plug thread chaser in a 94 lt1 (fleetwood) lisle part number LIS20020 and did the trick with putting grease in the gaps on the threads to catch shavings. it worked perfectly and now the plug screws in just fine. i cant recommend it enough. cost me ten bucks. try it!
Old Sep 10, 2014 | 09:36 PM
LANDSHARK1's Avatar
LANDSHARK1
Terrific!
That's good to know
Old Sep 10, 2014 | 10:04 PM
Impala Balko
I will let you guys know tomorrow, I have my mechanic making a house call to clean up my mistake. Hopefully I get this sorted out tomorrow so I can get her on the rollers on Saturday.
Old Sep 11, 2014 | 02:52 PM
desertmike1's Avatar
desertmike1
Good Call
This is not the place to learn something new without help..
Old Sep 11, 2014 | 04:48 PM
  #33
jake corvette's Avatar
jake corvette
Just me bit I always use "no-seeze" on plugs that screw into aluminum heads. Have used both aluminum and copper stuff with equal results. Doesn't take much so a small tube will last a long time. Kind of messy though so take care. Use a small solder brush - the kind plumbers use.
Are you sure there is not a portion of another spark plug - the threaded part - still in that hole? The fact the ground electrode is getting bent flush against the center electrode has me wondering.
Jake -
Old Sep 11, 2014 | 10:21 PM
  #34
Impala Balko
Well my mechanic was able to tap it out.... threads look great and I have the new plug in... He confirmed that it looked like the plug wen in crooked enough where the ground strap pushed against the spark plug hole and bent it. Here is a picture of the plug hole prior to repair.
Old Sep 11, 2014 | 10:33 PM
  #35
WVZR-1's Avatar
WVZR-1
It damaged the taper seat also it appears. Did you run the new plug in and remove it to confirm that it maybe "corrected" the taper on the seat? I certainly would. It looks like you've got what it takes to get a real good look or at least snapshots so I'd certainly take a look at the spark plug sealing surface. I'm amazed that you actually "wrenched" on it as hard as would have been required to accomplish what you did with out realizing there was a problem before that much damage was done. If it's fixed now you're fortunate. Patience!
Old Sep 11, 2014 | 10:53 PM
  #36
Impala Balko
Plug was run in all the way seated fine removed... debris was shop vac'd out and the engine was turned over with the header off so any loose shavings would come out as well. Anti seize was applied to the plug and installed. ... I got real lucky on this. .. I just think i rushed it too much and it turns out the plug was defective out the box that is why it wouldn't thread more than a couple of turns... The damage on the seat I think was leftover anti seize
