Headlight bushings....
Old Jul 29, 2002 | 01:27 PM
GiDvEtTe84's Avatar
GiDvEtTe84
Default Headlight bushings....
Can someone give me the measurments of the headlight bushings for the late model C4 gear? Thanks.
Old Jul 29, 2002 | 09:27 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Headlight bushings.... (GiDvEtTe84)
Someone posted on one of the current headlight posts that they had found some "metal" nuts that were the right size.
Personally, I would stick with the plastic/nylon. They are supposed to be somewhat "sacrificial" absorbing the "shock of the metal worm gear against the nylon drive gear for the momentary time when the lights are up or down and the motor is still turning.
Using metal instead of the nylon bushings could wear out the drive gear...just my HO :D
Old Aug 3, 2002 | 02:11 PM
GiDvEtTe84's Avatar
GiDvEtTe84
Thanks for the reply. I think it is the bushings. I was planning on making some out of wood. I think it would work. Please help! Thanks!
Old Aug 3, 2002 | 03:57 PM
GiDvEtTe84's Avatar
GiDvEtTe84
Well, I tried to take the motor apart while leaving it on the car. Of course! There is one little bolt thats behind a F%^&$G bracket! Whats the best way to get to the bushings? Take off the headlight assembly? I sure hope not. :boxing
Old Aug 3, 2002 | 04:43 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
The best way is indeed to take off the headlight assembly. It is actually so easy you will curse yourself for not doing it sooner. There is an excellent write-up in the C4section of Tech Tips to guide you.
I bought a 3 delrin bushing kit from Eckler's for my 88 and after seeing how easy it was to remove the headlight assembly I decided to to the other headlight before it went bad. I used one of the delrin bushings as a guide at the hardware store to get 3 more nylon bushings. I found that the 27/64 x 29/64 nylon spacer sold at Home Depot was as close a match as possible. They come 2 to a package at 29 cents per package.
The nylon spacers work just like the delrin bushings except they aren't as naturally slick as delrin. I doubt that it matters, but I'd put a wee bit of lubricant on them (marine bearing grease is perfect). Only had the fix in for about 6 months, but no problems so far.
The first headlight takes about 1~2 hours depending on how careful you are and how much you clean. :yesnod: The second one takes about 45 minutes. Be sure to have a 1/8" pin punch as well as all of the other tools listed in the Tech Tip and it will go real easy. You don't need to take the motor itself apart. Just loosen the assemblies it is attached to.
Old Aug 5, 2002 | 11:05 AM
GiDvEtTe84's Avatar
GiDvEtTe84
Default Re: Headlight bushings.... (Mike_88Z51)
I read the article. Thanks for the reply! I will look into this ASAP! :cheers:
Old Aug 5, 2002 | 11:25 AM
Nathan Plemons's Avatar
Nathan Plemons
I just replaced mine saturday. It's really not hard to get the headlights out of the car, not on the 92 anyway. 6 bolts and the entire assembly comes off.
Old Aug 5, 2002 | 05:46 PM
GiDvEtTe84's Avatar
GiDvEtTe84
Default Re: Headlight bushings.... (Nathan Plemons)
Can anyone tell me the diameter of the bushings?
Old Aug 5, 2002 | 05:53 PM
Mike_88Z51's Avatar
Mike_88Z51
GiDvEtTe84,
That's 27/64" long by 29/64" diameter. UPC # 30699 87278. :flag
Old Aug 5, 2002 | 05:57 PM
tbmoore's Avatar
tbmoore
Just remove the whole headlight assy. then remove the motor and install the new bushings. Ordered mine form mid america last week. $4-$5 a set and rebuilt both lights in under 1.5hrs.
Old Aug 5, 2002 | 11:09 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
loosen the two screws where the bracket holding motor mounts to main bracket and that will allow you to raise motor bracket high enough to get that screw out.also is your headlight going up or not.if it is not even moving then check the motor and see if it is turning the rotating mechanism.if motor doesnt even try to move it then the motor is probably shot as mine was.I replaced right side and now the left side is taking a CRAP.I think the motor gets dead spots and would only move if I turned the postion first.then next time it wouldnt work again.I replaced bushings first and that didnt help.the bushings can be bought for under 10 bucks.
To Headlight bushings....
