Dana 44/spicer1310 how much torque
Old Sep 8, 2014 | 06:50 PM
vstol's Avatar
vstol
Default Dana 44/spicer1310 how much torque
I was ordering my drive shaft today for my project below and they said that the 1310 (dana 44) only take 400lbs of torque so they said to relook at what I'm doing. I have a LS3 427 618hp and 574 lbs torque at 4800 rpm. I called Dana/Spicer tech department and they said instantaneous torque for a 1310 is 800 lbs. Any issues out there with compatible HP/TQ, thanks
https://www.corvetteforum.com/forums...ica-kinda.html
Old Sep 8, 2014 | 06:57 PM
rklessdriver's Avatar
rklessdriver
Shouldn't be a problem with them.
I still run 1310s in my race car and your talking 722hp and 600tq on motor with a 200 shot on top of that... 1.24 60ft and the driveshaft joints last all season no problem.... the 1350 Halfshaft joints are another story.
Will
Old Sep 8, 2014 | 07:28 PM
383vett's Avatar
383vett
Does your car have a manual or automatic? Will you be running stickies at a track. If you're running street tires, not to worry. If you are going to run stickies at a track, Rkless will have a lot of advice for you. His car is just plain mean.
Old Sep 8, 2014 | 08:47 PM
vstol's Avatar
vstol
thanks no slicks just autocross and some fun road racing with a TKO 600 5 spd
Old Sep 8, 2014 | 10:05 PM
Blue Vert 91's Avatar
Blue Vert 91
that build is incredible, you got a lot of talent going on there
Old Sep 9, 2014 | 06:04 AM
vstol's Avatar
vstol
thanks
Old Sep 9, 2014 | 07:17 AM
WVZR-1's Avatar
WVZR-1
A local vendor for the drive-shaft or one of the Internet vendors? What diameter and wall thickness for the tube? The OE is 3 X .120 seamless for the 1310 applications. There are very few that do the .120 I believe. The OE had the silencer/dampner internally also.
Old Sep 9, 2014 | 06:26 PM
vstol's Avatar
vstol
Thanks Will it is American Power Train. I will use this data and pass it on to them
To Dana 44/spicer1310 how much torque
