Need the pros here!
Post with more details right HERE.
If you can hook a scan tool up and watch your RPM signal when the symptom is occurring, that will give you the answer about the OPTI; if your tach signal goes wacky, the OPTI or harness to the ECM isn't working correctly (more likely the Opti, IMO). If you tach signal is stable and accurate, then the OPTI is doing it's job and the problem is elsewhere.
http://youtu.be/T2rh35e8-qU
If you can hook a scan tool up and watch your RPM signal when the symptom is occurring, that will give you the answer about the OPTI; if your tach signal goes wacky, the OPTI of harness to the ECM isn't working correctly (more likely the Opti, IMO). If you tach signal is stable and accurate, then the OPTI is doing it's job and the problem is elsewhere.
What do you mean by goes wacky? It shows the studder as a misfire would but the rpm signal does not fall anymore than maybe 150-200 rpm when it happens. it literally feels like its hitting the rev limiter.
If you feel confident that the crank is humming along at a constant speed (car speed is constant, obviously), and the tach signal is falling off, that doesn't look good, for the opti.
You can also view your high and low resolution signals w/a scan tool, take freeze frame and look at that signal more carefully.
I have a new ICM on the way. The optical side of the distributor looked good so I am going to put it back together and see what happens. If I have to take it out again and replace it then so be it. I just hate to spend the 500 if I dont have to.
By going back to factory ignition and watching the problem get 100% worse, I think its definitely opti or ICM related. So we will see. Im going to have it all up and going tomorrow. I have to wait for a new distributor seal to come in before I can put it back together. In the mean time I am going to clean everything up under the hood and change my leaky power steering pump. Dang cars....,
"the factory ignition it wouldnt rev past 2500 rpm"
That may be your answer or your way to find out.
Hook up the Factory crap and then Diagnose your problem. It should pull up to 4000 rpm or more even with Boost.
Once you solve that, I think it should pull well into 6000 rpm with the msd because the msd is covering up a problem
Or your problem was all that blue dust that could be some kinda metal that was causing all kinds of miss firing inside the cap. It's got to be.
I'll bet you my Escort for ur Vette with it cleaned up now without the msd it will pull up to 5000 grand or so
And don't forget about that damn stupid Corrective cap for nice plug wire routing that comes with a price. The "Correct-a-Cap" design that places the spark plug wire terminals on the proper side of the engine for easy spark plug wire routing. To do this, the terminal traces molded into the distributor cap must come extremely close to one another, which leads to premature arc-over in high-load applications and applications using constant high-voltage (Capacitive Discharge) ignitions. Not good.
New Module and I bet it will rev to red-line without the msd-cd. Man I 'll even send-ya a know stock good one and you can send me 20 bucks for a Hooker and an extra 5 for a beer for the Advise for ur problem thats been going on since, last month or so just after you put the pro-charger on. That module has been bad for a while now causing all kinds of crap.
That think deserves a 550-750 dollar belt drive crank trigger Dist and plug that opti when your ever thinking about spending 500 on a stock replacement of that crappy opti and put a real dist cap on that thing and never have these problems again and you will be able to have full use of the MSD-CD Ing's. Its a Mitsubishi Designed and used set up anyways and on all the Mitsu's its used on they are fine, for a Mitsu, and they didn't put that stupid cap on them that don't handle CD Ing
The issue was the car having a hesitation at 5000 rpm only after 45 minutes of driving. . . . Not all the time like a typical opti problem. Most opti that fail have a high rev problem all the time- not just when it's hot!!!
And BTW:: there have been several different ignition issues since I put the new blower setup in. Not just one on-going issue. Its part of building a high horsepower car on a old platform. Atleast its not detonation like you were so persistent about in my first thread lol.
https://www.google.com/search?q=sbc+...ml%3B576%3B384
Also, Dynotech Engineering is working on two other projects: an upcoming Gen. I distributor for the '92-94 LT1s will share the same upgraded internal components and refinements of the Gen. II model. And the "Gen. III" distributor will be rotor-less and capable of 8500 engine rpm. The Gen. III is designed to work with the LTCC and individual LS1/LS6 ignition coils and will have all of the same improvements as the Gen. I and II, but with a billet aluminum cap in place of the OE plug wire cap and a lightweight reluctor wheel support. Owners of the Gen. I and II DynaSpark Distributors can always upgrade their current unit at a later time to the Gen. III unit by purchasing the "high rpm kit upgrade", which will allow them to utilize individual ignition coils and the LTCC. You can view the DynaSpark at www.dynotech-eng.com.
LTCC: Opti-Spark Alternative
The LTCC (LT1 Coil Conversion) grew from the need for a high-energy ignition system for the LT1 that did not use the distributor section of the Opti-Spark. The optical portion is reliable and is needed to keep the stock PCM happy. By using the Opti-Spark Hi Resolution and Low Resolution signals to feed the LTCC, the interface can decode which cylinder is being fired by the PCM and direct the timing signal (EST) to the appropriate coil. The LTCC also calculates its own dwell (coil charging time) and can begin charging the next coil in the firing order before firing the current coil. This allows full spark power at very high rpm. The LTCC can be run to 8000 rpm, much higher than most anyone runs an LT1. For high rpm operation (>6000 rpm), it is a good idea to remove the rotor from the Opti-Spark as it tends to shatter.
The LTCC system consists of an interface unit and plug-in wiring harness. Other than connecting to 12 volts to feed the coils and the EST wire, all connections are direct plug-in using OEM weatherproof connectors. The LTCC features a spark-based rev limiter (2 stage) and a timing retard that has built in curves for turbo, N2O, and supercharger applications. Both the retard and rev limiter can be enabled full-time or triggered. The LTCC has a trigger wire that can be configured to activate the second rev limiter stage or the timing retard.
In addition to the LTCC kit, the user needs to obtain 8 LS1 coils, plug wires and a way to mount the coils.
The wide array of header styles, valve cover dress-ups, and turbo systems has made the design of universal coil brackets a challenge. As of this date no truly universal bracket is available. Installations have been done on top of the intake plenum, and even on the frame rail (race application). The interface is a gasket-sealed aluminum box and can be mounted underhood. See the LTCC at www.bailey-eng.com
Is Your Opti-Spark Failing?
LT1 owners have dealt with the Opti-Spark distributor for 11 years now, but there is still much confusion regarding the causes and symptoms of a failing unit. Tapping into the PCM with a scan tool is a good way to start, but sometimes no codes will be set. Before diving into the Opti-Spark, be sure to verify that your grounds are good and the coil and wires are not the source of the problem, as they are much easier to change.
Symptoms:
* Car suddenly dies and won't restart
* Starts but immediately dies
* Extended cranking to start
* Rough idle
* Sputtering
* Backfiring
* Trouble reaching higher rpm
* Black smoke from exhaust
* Poor performance with car warmed up
* Weak plug wire spark
* Codes 16, 36, and 42 may be set
Read more: http://www.superchevy.com/how-to/031...#ixzz3DRWRzJnI
