No power/ ground issue
see what you are not understanding the amount of connection you need to show you have 12 volts can be delivered thru something as small as a common desk staple, but would not stand a chance of doing much more. hence you have cables the size of a finger with connections that could be removed with a lug wrench.
have you checked the connection at the starter? and if you do Disconnect the battery
I don't know that chasing fuses will answer anything, if I'm not mistaken, a fuse is either work or fail, not really capable of intermittant failure? Maybe I'm wrong, but I've never seen it.
The car going completely dark is the key here. You are losing a connection somewhere in the direct power line. Those 12.5 volts are not going anywhere. There could very well be a break or a short in the main battery cables, either pos or neg as well.
so next time it happens pay attention to what you touch and tug on
and since you have changed some cables and you are sure they are connected good, I am starting to wonder if you might have a cracked post inside the battery, again when it acts up with out touching anything use a good set of jumper cables and remove battery from the equation by using a independent battery.
Here's my update. I put a brand new battery in the car this morning. I didn't hear the headlight motors but the dome lights went on and the car started right up. When running, I was seeing around 14 volts(alternator must be working).
I drove it around the block about 300 yards and over a few speed bumps and dips at about 15 mph and came back to the house. After letting it sit for a minute, I went to see if I still had power. I had nothing. I tried moving the ground and I still have nothing.
During the drive, I noticed that the car started missing a little. It still drove but didn't sound 100%, like it was running on 6 or 7 cylinders.
When I free rev'ed it, it sounded okay but at part throttle driving, it did not. I've never experienced this except for the past two times I drove the car.
Now for measurements.
Power across the lugs of the battery, 12.5 volts. Power from the distribution block behind the battery, 3.4 volts! I checked twice to verify. Isn't that thing supposed to be hot all the time? What can I check in sequence for bad connections? When looking at my Haynes manual, there is a chart that says that the battery goes to the alternator and the starter, but where else, if anywhere does it go? What should I check?
So, off to the next step in the chain. After leaving the battery, it looks like it goes to the starter. Is that correct? I've got the passenger side of the car up in the air, so hopefully that'll help.
I did the exact same drive as last weekend and the car started again once I got home.
Prior to leaving, I measured 12.4 volts at the distribution block behind the battery prior to the drive. I also measured 12.4 at the alternator lug.
So, I'm kind of dead in the water until I can get the situation to happen again and measure various places for voltage. If it does happen, any additional places that I might want to measure for voltage?
I installed the new alternator today which was super easy. The car now reads 14.3 volts off the dash at idle. The alternator was off a 1996 and was with very low mileage.
A quick question; if the fusable link to the jumper block behind the battery is going bad, would it cause a no power situation similar to what I'm experiencing?
I'm going to go buy a $3 fusible link and add another wire to my positive post and see if it fixes the condition. I already have a second nut on there for the stereo system so it'll be added there. Hopefully that will do it on the electrical side.
