headlight
Old Sep 19, 2014 | 12:07 PM
85vegasvette's Avatar
85vegasvette
Default headlight
went out for an eveing ride, to the strip no less...parked came back few hours later and turned on lheadlights and one side got helled up, taped the side of the headlight motor and a ok, this happened a few months ago and i did the same thing ...so my question is, is it the busshing? it makes no sounds when worksing at all..and the tap with the ballpein hammer works...should i wait till its fried >>replace the motor?
Old Sep 19, 2014 | 12:11 PM
bogus's Avatar
bogus
that sounds like a bad motor...
Old Sep 19, 2014 | 07:54 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default 1985
MY 85 only needed new headlight gear to make it work like a new one. Easy to replace the gear if you would like to tackle the job.
Old Sep 19, 2014 | 10:30 PM
leesvet's Avatar
leesvet
if it works again with a tap....that's NOT the gear. Its the contact breakers inside the motor that are burnt and in need of adjustment. Once apart, installing 2 new gears sure won't hurt.
Old Sep 20, 2014 | 11:54 AM
85vegasvette
yeah as soon as the 90 plus days are gone i will tackele that issue, and probably change the lights on the dash, every once in awhile have to give a little love tap to have them pop back on...lol
Old Sep 20, 2014 | 11:57 AM
85vegasvette
i would say with all the little love taps my little white bitch likes id say she is a bit kinky.....lol
To headlight
