1987 Cold Start Injector Line Leak
Old Sep 21, 2014 | 11:23 PM
Stephenms's Avatar
Stephenms
Default 1987 Cold Start Injector Line Leak
Hey everyone! I'm having problems with my cold start line. After I did a second intake rebuild (long story) I am having fuel spray out of the rear of my fuel rail, at the 9th injector line. When I was reinstalling I was extremely frustrated because my driver side runner gasket would not sit, spent at least an hour trying to thread one bolt. I ended up being a little rough with the cold start line. The line itself has always leaked a tiny tiny bit but not enough for me to spend 200 dollars on a new line. It is now spraying fuel whenever the key was in the on position, I pushed on the line with a screw driver and now it's at a small dribble in the on position. Is there a way I can remove that line, put a new o-ring or sealant and call it a day? Or do I have to purchase a new line? The line itself is not ripped or cracked or damaged. It's leaking from the back of the fuel rail itself. I believe there's a double threaded nut that sits on the back of the fuel rail, then a threaded cap to hold the cold start line into place, right? Could I replace that cap or nut?
I was researching about the cold start delete kit. I can get the blocking plates on eBay or K & B Corvette for about 30 bucks delivered but I would have to reprogram my ECU. I don't have the tools to reprogram my ECU so I'm not sure about that option and a new wiring harness is a pain. Would it throw a code because of the sensor? If it's what has to be done to get this car drivable again then I have no other choice. Any ideas? This is my daily driver and I need it back on the road ASAP.
Old Sep 22, 2014 | 12:35 AM
Cliff Harris's Avatar
Cliff Harris
I had a leak at #107 in this picture. The fuel rail has a 45° bevel inside the hole that #105 screws into. The sharp edge of the bevel was slicing off part of the O-ring and causing a leak. I had to replace several O-rings before I finally figured out what was happening. I sanded off the sharp edge and polished the inside of the rail to fix the problem. No leaks now.
Old Sep 22, 2014 | 12:51 AM
JackDidley's Avatar
JackDidley
In Florida you dont need the CSI. Block it off and you will never miss it. No programming needed, unless you move to Canada.
Old Sep 22, 2014 | 08:17 AM
Stephenms's Avatar
Stephenms
That was another question I had. Here in Florida it gets slightly less hot in the winter so there's not much of a need for CSI. If that's the case then i'll be ordering a block off kit today.
Old Sep 22, 2014 | 03:20 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Not even needed in Canada, mind you, I park mine from Dec to March.
Drove for a year on the stock tune and no CSI and don't recall any starting problems.
Old Sep 23, 2014 | 10:29 AM
Stephenms's Avatar
Stephenms
Aluminum delete kit was ordered fresh off eBay for 30 bucks delivered, should be here Friday. I'll inspect the line and see if I can either resell or just give away if anyone is looking for a stock look. Thanks for the input guys!
Old Sep 23, 2014 | 11:01 PM
ghoastrider1's Avatar
ghoastrider1
I just posted about this a week or so ago. gave the part number @auto zone and price of $4.59 for a reseal kit for the fuel rail, including the cold start (9th) injector. I believe the part number.. for any parts store..is SK24. If you are giving away the 9th system.. Raiseing hand to accept. I have another manifold I am trying to part together..
To 1987 Cold Start Injector Line Leak
