Part number needed
Old Sep 24, 2014 | 11:47 AM
CharlieLT4's Avatar
CharlieLT4
Default Part number needed
Need to purchase the mounting bolts/nut on the rear of a 1994 muffler. Any one have a part number?
Old Sep 24, 2014 | 12:15 PM
WVZR-1's Avatar
WVZR-1
Do you want hardware to hold the rubber cushion/bracket to chassis or the bracket that is attached directly to the rear of the muffler? The stud is originally part of the muffler assembly and used a single flanged nut on each side, that nut is a M10 X 1.5 flanged head. To the chassis there's a stud plate and then two nuts each side that secure the cushion/bracket to the chassis. The nuts to the stud plate are M8 X 1.25. Here's an image that displays what I mentioned but the nuts aren't part #'d in the image:
http://parts.nalleygmc.com/showAssem...=0&modelYear=0
You could undoubtedly substitute M8 bolts and an M10 bolt where needed I'd think in some fashion.
Old Sep 25, 2014 | 08:15 PM
CharlieLT4's Avatar
CharlieLT4
Thank you. I appreciate your time.
To Part number needed
