Misfire on #6
Old Sep 26, 2014 | 10:21 PM
anglaw1's Avatar
anglaw1
3rd Gear
Default Misfire on #6
Totally lost! 1985 - suddenly just quit. Hard start then just would not stay running. Buddy checked and fuel pressure was dropping. Maybe fuel pump?-replaced. Still would not run. Finally gave up and took to garage. Hose to PVC replaced, will now start and run but mis-firing on #6. Replaced fuel injector on #6. Runs ALOT better but still missing on #6. Replaced all 8 injectors. Checked cam for flat spots, lifters checked, checked for carbon build up. Excellent compression,no wet or fouled plugs and everything checks out but still misses on #6 when running 35 MPH or less. When idling will sometimes miss and sometimes not. Runs like a dream over 35. Not sure if distributor was checked?? Very reputable mechanic is totally stumped to the point of all labor has been written off and only paying for parts. ANY IDEAS? I am losing my mind.
Old Sep 26, 2014 | 10:33 PM
DanielRicany's Avatar
DanielRicany
Mine did that. Was a bad ignition wire. Check for cracked spark plugs and torn wires. Also ohm out your wires. If one of them differs greatly, that is the one that is bad. Not sure what wires you have but take the ohm reading and divide it by the length of the wire in feet. That will tell you how many ohms per feet the wires should be.
Old Sep 26, 2014 | 10:36 PM
playsdixie's Avatar
playsdixie
easier way....swap 6 wire for 4.....see if miss goes with wire...
Old Sep 26, 2014 | 10:37 PM
DanielRicany
Yes that's a good idea too.
Old Sep 27, 2014 | 01:03 AM
Cliff Harris's Avatar
Cliff Harris
I had a miss on #6. I found it by looking at the spark plug wires in a dark garage. It was arcing to the oil dipstick tube. When I pulled the plug boot off the plug it fell off the spark plug wire. The inner conductor was burned away by the arc inside the wire. When the gap inside the wire got big enough it was easier for the spark to go to the dipstick tube ("the path of least resistance" in action).
Old Sep 27, 2014 | 05:16 PM
anglaw1's Avatar
anglaw1
3rd Gear
Thanks for all the suggestions! Will check to see if plug wire/wires have been replaced. I know plugs are all dry with no cracked conductors. I assumed that when he checked plugs for damage, moisture and gap, he checked wires and distributor. But you know what assuming will get you. Will ask specifically if that has been done.
To Misfire on #6
