bad brake
Old Sep 27, 2014 | 08:51 PM
silver1996lt4's Avatar
silver1996lt4
5th Gear
Default bad brake
started runnin my 1996 collecters edition on track . at barber after 7 laps brake boil lose all pressure . is wilwood 600 fluid gonna work with abs?
Old Sep 27, 2014 | 10:19 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Any good quality fluid will work w/ABS.
Lasted 7 laps huh? Mine only lasted 5 at Miller on the stock brakes and auto parts store fluid.
Old Sep 28, 2014 | 02:39 AM
Cliff Harris's Avatar
Cliff Harris
Don't use silicone brake fluid. It is not compatible with ABS.
There are several good brake fluids available. A lot of people like Motul (made for racing motorcycles). Some use Ford racing brake fluid. I like Castrol SRF (expensive, but I've never boiled it). There are probably others I don't recall offhand.
Old Sep 28, 2014 | 03:41 PM
silver1996lt4
5th Gear
thank you all for your help
Old Sep 28, 2014 | 09:23 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Where have you heard or read that? I believe that it's fine for ABS, the hitching point is flushing or cleaning out the conventional fluid thoroughly enough to use silicone.
Old Sep 29, 2014 | 12:43 AM
Cliff Harris
It's in the shop manual, page 5-1:
"Do not use silicone brake fluid such as Delco Supreme No. 24. Any type of silicone brake fluid may cause seal damage".
Old Sep 29, 2014 | 12:30 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Ah! Perfect. That is good to know, and thanks for posting it.
To bad brake
