Brass Gear Headlight Upgrade
Old Oct 1, 2014 | 10:27 AM
Eran X. Jones's Avatar
Eran X. Jones
Default Brass Gear Headlight Upgrade
Did the brass gear upgrade today on the headlight motors on "Beauty" the 1994. My only concern is that the pellets could fail again due to them still be made of Teflon. Has anyone experienced this after this upgrade?
Old Oct 1, 2014 | 10:53 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Those pellets act as a torque limiting clutch, so that if something jams in the headlight mechanism, the clutch will slip rather than shattering the pivots in the housing! They slip a little every time the housing hits the stops at the end of their opening or closing travel.
Old Jun 5, 2019 | 06:57 PM
ChrisLSx's Avatar
ChrisLSx
Update: After running them for a year and a half, the case split (the epoxy didn't hold). I switched out to fixed headlights which are much brighter but I miss the way the car looks with the lights down. If I decide to go back to popups, I'll convert to the older bolt together motors so they can't split again.
Old Jun 6, 2019 | 09:01 AM
puterami's Avatar
puterami
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
2020 C4 of the Year Finalist - Unmodified
2019 C4 of Year Finalist (stock)
Since you gave an update yesterday I thought that I would chime in.
I use the exact same "pellets" in window motors for my two Fox Mustangs.
I replaced the two in my 84 18 years ago and the 4 in my 85 convertible 6 years ago.
They have lasted fine since.
FYI, I also replaced the ones in my 96 Corvette a couple of months ago, yet did not upgrade to brass gear.
Old Jun 6, 2019 | 06:06 PM
Hot Rod Roy
Originally Posted by puterami
I replaced the two in my '84 18 years ago and the 4 in my '85 convertible 6 years ago.
I'm sorry to inform you that there are no "pellets" in the '84-'87 headlight motors.
Old Jun 7, 2019 | 09:20 AM
puterami's Avatar
puterami
I wasn't clear enough.
I replaced the two in my 84 (Mustang) 18 years ago and the 4 in my 85 convertible (Mustang) 6 years ago.
Note: The window motors in my Mustangs look *exactly* like the two headlight motors in my 96 Corvette. Hence, same pellets.
I posted to give testimony that the pellets have worked fine in two motors for going on 18 years now and 4 motors going on 6 years.
Old Jun 7, 2019 | 12:25 PM
Pwnage1337's Avatar
Pwnage1337
Still not clear enough, can you post pictures of the cars to prove that you own two mustangs? To make sure it's not a picture from the internet I need you to write on a piece of cardboard "peanut butter sandwich" and hold it up while you stand next to the car.
Thanks!
Old Jun 7, 2019 | 03:03 PM
puterami's Avatar
puterami
I would, but I don't know how to spell "peanut butter sandwich".
To Brass Gear Headlight Upgrade
