Horrible braking
I assume you have tried simple things like new fluid, new flex lines, new calipers or maybe rebuilding them, and new rotors? What pads do you have on the car now? There are lots of good performance pads available for the early C4 brakes.
How much material is left on the pads? If they show wear down to say 25% of new, then I would go ahead and replace them. Hawk makes a good variety of performance pads; for something like autocross and drag racing, try the HPS or High Performance Street pad. This is also a good street pad.
Measure the rotor thickness too. The rotors should have a minimum thickness cast into them. If they are at that limit or close, toss them and get new rotors. NAPA, Raybestos Professional Grade, StopTech, and Centronic all have good street/performance rotors.
Without ABS, you will have to get in some braking practice. Get to where you can stop the car hard without locking up a wheel.
For fluid, use a quality DOT3 or DOT4 fluid. While you have already done a flush, a really good fluid will help handle high temps so the fluid doesn't boil. For a good DOT4 fluid, try ATE Typ200. MOTUL is another excellent DOT4 fluid. For a DOT3 fluid, I hve used the Ford
MotorSports HD fluid. You can find that at any Ford dealer parts counter. Also Castrol LMA or Valvoline.Because I use my 87 for primarily autocross and track days, a few years ago I upgraded the front brakes to C5 stuff. The parts were around $700. But this conversion requires 17" wheels. Look at the Vette Brakes website for info on that conversion.
For those who are reading this thinking I am a jerk, read through his other threads whereby our best members try to help, but this guy has better ideas he heard through his friends....and ultimately the car continues to give him grief and he keeps asking us for ideas that he questions......
for example when someone gives you advise here, take it (because you are obviously not educated on these cars and do not possess the mechanical ability to handle it yourself) nor do you seem to be in the financial position to hand it over to a knowledgeable/capable technician.......
When that happens I will be happy to give good solid advise from things I have learned;
and stop posting juvenile threads making it very difficult to take you seriously.....it's like talking to a 14 year old.....you are obviously a younger guy, but you don't need to establish your juvenile demeanor.
My '87 only has some mild mods and the cam is a early GM ZZ3 cam which is apparently is not much of an upgrade over a stock Corvette L98 cam for that year, so there is plenty of vacuum at the booster. But the pedal on my '87 doesn't seem to be much different than what the pedal feel is like on my '02. I use stock C5 Z06 pads on the '87 up front and Hawk HPS on the rear. This combo works great for the street and for autocross, and I have never seen severe brake fade doing HPDE's at local road courses
I would suggest getting some stainless lines and try some Hawk HPS pads to start. If the current rotors look OK, maybe just have them checked to make sure they aren't warped and maybe turn them. With most aftermarket pads, it's a good idea to "bed" the pads to transfer pad material to the rotors. Hawk recommends this.
C4Cruiser is on the right track.
Check the front brake pads, i know standard car type pads wont work on a C4. You need a high metal content brake pad to create the friction you need to stop the car, rather than just slowing it down.
(that is what my 85 was like when i first got her, i could stand on the brakes and the car would barely slow down. New high metal content brake pads fixed it, so i just have to lightly touch the pedal to brake hard)
Hawk Hp are great but can be noisy and dusty, i would reccomend the Hawk street brake pads (corvette central have them)
Yes check your booster, run the engine rev it a few times and turn the engine off and listen for any hissing.?????
Inside the cabin and engine bay, if all is quiet replace the brake pads.
REMEMBER if your discs have wear, it is a good idea to get them machined. It will take a long time for the brake pads to "wear" to the disc surface irregularities.
If you do not machine the brake pads, lightly apply the brakes for the first few miles so they wear into the shape of the discks.
It can be really bad with hardly any braking at first, untill the brake pads wear and make good contact over the disc surface.
Good luck, the 84-87 brakes were not bad they worked great with the right brake pads.
Before runout, a functioning booster will multiply the input force by a factor of about 8.
lining friction may vary somewhere between 0.3 and 0.4 under normal conditions, which is minor by comparison
Since these boosters (especially replacements) are very prone to leakage through the pushrod seal, through bolt o rings, diaphragm and/or shell, that's what I'd check first.
Try braking with and without vacuum to the booster. Difference in pedal effort should be night and day if booster is doing its job.
That's just it, you aren't learning a thing, you are too busy trying to prove us wrong.
I agree with 85. Daniel, is there any part of your car that is not broken? If I were you, I would cinch up the seatbelt, don a helmet and test the brakes by applying them just short of hitting a brick wall. Best case scenario is that the brakes don't work, the car is totaled, the insurance pays off and you can start with a newer car with no problems. You have spent much time and energy on your project and you seem to take one step forward and two back at every turn. I am not being a smartass. Sometimes you just need to reboot and start over.
1) Get new pads front AND back( I just got 25 dollar raybestos)
2) Put new fluid and make sure they are bled properly.
3) Regrease the rods that the caliper uses(sorry can't remember the name) use brake type grease
4) I sandpapered the ridge of rust off the rotors and it stopped making a rough sound.
5) I drive around the canyons and they work 10x better I still need to get new rotors and change 3 more brake lines. My booster seems normal
Good luck
Good luck
I replaced it all and did hours or research and conversation. I replaced rotors, pads, ABS, flex lines, and master. Booster always worked fine, no leaks so I saw no need to replace it. Also did a lot of testing and bleeding.
I finally replaced the brakes with a J55 system 13" rotors. My braking was dramatically improved with the pads that came with the used system (in pristine shape). When pads wore out replaced the pads with hawks had similar problems. Found Brembo pads and worked excellent (not available anymore).
Fast forward to 2010 my booster went bad with a classic leak. Got a booster from AZ and installed it. My braking power was so dramatically improved I could not believe it. I didn't fully understand it but results don’t lie.
Just saying.
But then you say you will address them when you get around to it? Why bother posting?
I had my master rebuilt by cardone, new metal brake booster, new ss lines replacing the rubber lines, DRM bias spring, rebuilt and PC'd all calipers, and new hawk ceramic pads front and rear. This made a considerable improvement in stopping power and pedal feel. I wish I had known about J55 upgrade before I started.
You have a million problems. The problem is you. Take advice and try to fix it or sell it and get an atv or something because those are the forums you belong on. So many great people here are giving up on you after trying time after time to help you with you not listening or trying their advice.
Mike
