anal idle
Old Oct 5, 2014 | 07:54 AM
playsdixie's Avatar
playsdixie
Default **** idle
try to always keep the idle at 650....yet at idle it shows anywhere from 64-66, 67 when idling...even though it's idling smooth....sometimes it take a few seconds for it to get down to the proper idle.....sometimes drops right down....is this normal?...am I mising something?.......can I expect it to stay at 65 only when idling....?? Just wondering why sometimes it's slow getting down.....
Old Oct 5, 2014 | 08:48 AM
ex-x-fire's Avatar
ex-x-fire
So your talking about a 10-20 rpm surge? Most likely the a/c and/or cooling fan turning on causing that.
Old Oct 5, 2014 | 08:59 AM
WW7's Avatar
WW7
Clean your IAC , take the bottom off the throttle body and clean the passages the air travels through...These get gummed up and can cause the IAC to stick or react slowly..Use carb cleaner or throttle body cleaner to clean off the pintle (tip) of the IAC.....WW
Old Oct 5, 2014 | 03:05 PM
playsdixie's Avatar
playsdixie
put a new one in last year and tb is new, but i'll give it a shot and look...
Old Oct 5, 2014 | 03:11 PM
playsdixie's Avatar
playsdixie
I guess what I was asking was should it hold right at 65 or does everybodies wander a bit???...
Old Oct 5, 2014 | 03:14 PM
DanielRicany's Avatar
DanielRicany
Mine is cammed and it wonders up to 200 RPMs. Just for reference.
Old Oct 5, 2014 | 03:33 PM
cumbercr's Avatar
cumbercr
I have a Crower 221/230 cam and I'm able to idle at +/- 20 RPM. I think a little wander is normal.
Old Oct 5, 2014 | 05:28 PM
playsdixie's Avatar
playsdixie
probably getting too damn ****....can only take fine tuning so far..
Old Oct 5, 2014 | 09:40 PM
WW7's Avatar
WW7
I wouldn't worry about a little bit of variation... I think as long as you don't have a hunting idle your fine...WW
Old May 27, 2021 | 01:28 PM
marcus427's Avatar
marcus427
i adjusted the throttle linkage like tooth doctor recommended, THANKS !
To anal idle
