Car runs different when scanning
Old Oct 11, 2014 | 01:16 AM
K87ZZ4's Avatar
K87ZZ4
Default Car runs different when scanning
When I plug in the ALDL adapter to read data, my 87 (OBD-I) runs differently. It idles higher and sometimes jerks when I let off the throttle entirely while on the highway.
I don't remember this happening in the past (but I used a different setup with a serial cable). Does this happen to anyone else when they connect up to scan?
I'm using a bluetooth adapter and running ALDLdroid on my phone.
Old Oct 12, 2014 | 10:19 PM
bjankuski's Avatar
bjankuski
It will run different because the stock tune adds 8 degrees to the global timing when the scanner is hooked up.
Old Oct 13, 2014 | 02:00 AM
Cliff Harris's Avatar
Cliff Harris
Some scan tools and cables put a 10K resistor across the A & B pins of the ALDL connector. In some cases there is a switch to take this resistor out of the circuit. In Diacom the switch is electronic and I can put it in or take it out.
From the shop manual (10K mode):
• Closed loop timers are bypassed
• EST (spark) is advanced
• IAC will control engine idle to 1000 RPM ± 50 RPM
• On some engines, canister purge solenoid will be enabled
• P/N restrict functions will be disabled
Old Oct 17, 2014 | 02:01 AM
K87ZZ4's Avatar
K87ZZ4
That explains it, then! I was wondering if, since it was running differently, it might also effect the data I was seeing (in my case, very high O2 values... running rich).
Thanks for the great info, guys!
To Car runs different when scanning
