difference between lt1 corvette and camaro intake...
Old Oct 11, 2014 | 06:55 PM
ICANTDR55's Avatar
ICANTDR55
Default difference between lt1 corvette and camaro intake...
what is the difference between the 93 corvette and the 95 Camaro intake. I used the Camaro intake on my vette and for some reason the fuel rail doesn't fit right. is there a difference in the two intakes?
Old Oct 11, 2014 | 07:08 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
The fuel feed/return lines are on opposite sides.
I did a quick search and found this:
http://www.nookandtranny.com/Info_LT1.html
There are 3 different LT1 intake manifolds, 92-93 LT1, 94-97 LT1 and 96 LT4. The 94-97 LT1 and LT4 intake manifolds appear the same from above, all LT4 intakes are powder coated red from factory, but the difference is in the intake ports. LT4 intake ports are raised, and use different cylinder heads and intake port gaskets. The 92-93 intake manifolds do not have the fuel rail crossover in the front like the 94-97 intakes, however the 94-97 intakes can use the 92-93 fuel rails.
There are a total of 4 factory fuel rails for the LT series engines : 2 different Corvette rails, and 2 different Camaro/Firebird rails. All of the Corvette rails have the feed/return lines on the passenger side, while the Camaro/Firebird/Impala all have the feed/return lines on the driver's side. 92-93 fuel rails do not use the fuel crossover in the front. 94-97 fuel rails use the fuel crossover in the front. You can use the 92-93 fuel rails on all of the intakes, but you can only use the 94-97 fuel rails on the later model intakes.
Old Oct 12, 2014 | 12:23 AM
bjankuski's Avatar
bjankuski
There is no reason your 1993 fuel rail should not fit the 1995 Camaro intake, the intakes between the vette and Camaro were the same. Read the note above on the fuel rail differences.
To difference between lt1 corvette and camaro intake...
