93 High Idle
Old Oct 11, 2014 | 09:44 PM
charliet615's Avatar
charliet615
Default 93 High Idle
I may have a vaccum leak that is causing this.. What is the best way to check all vaccum hoses? Idles at about 800 rpm's.
Old Oct 12, 2014 | 02:53 AM
Cliff Harris's Avatar
Cliff Harris
Check out the vacuum hose diagram on the radiator shroud. Find the source for each vacuum line and plug it temporarily while the engine is running.
The vacuum check valve under the passenger side injector cover is a known trouble spot. About $4 at any auto parts store.
Old Oct 12, 2014 | 10:49 AM
charliet615
Thanks, i'll check that out today..I've heard that you can spray starter fluid at the vaccum line connections and watch for a rpm change?
Old Oct 12, 2014 | 12:02 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Make sure that you have a fire extinguisher handy if you do that.
Old Oct 12, 2014 | 12:40 PM
charliet615
Yes, i have several fire extinguisher's handy, but is this a good way to check for vaccum leaks?
Old Oct 12, 2014 | 01:29 PM
FrankieD's Avatar
FrankieD
You can use one of those portable handheld propane torches ( like the plumbers use to solder pipes) and just open the valve and go around various engine spots until you see RPM change.
Old Oct 12, 2014 | 02:09 PM
charliet615
That's interesting, how do you do that on rubber vaccum lines?
Old Oct 12, 2014 | 08:41 PM
JC316's Avatar
JC316
He means to open the valve, but don't light the torch. Just let the gas out.
Old Oct 12, 2014 | 08:59 PM
charliet615
Now that might work.. Thanks for that...
To 93 High Idle
