Stall during warm-up
Old Jul 31, 2002 | 07:05 PM
pastor's Avatar
pastor
7th Gear
Default Stall during warm-up
I have an 89 C-4 which runs great, but if I allow it to sit at an idle during warm-up it stalls. Sounds like someone just turned the key off. The ECM also reads out a code 13 which means an open circuit in the Oxegen Sensor. I've replaced the sensor and checked and all the connections are good. It does not effect fuel econony or performance. It has the 6 spd trans, and on long drives gets 24 mpg fully loaded. After warm up the car runs great - good gas milage and performance, but the check engine light comes on and stays on after reaching normal operating temp. Got any ideas? This is my first Vette. :seeya
Old Aug 23, 2002 | 11:19 PM
Mo_Bandy's Avatar
Mo_Bandy
Default Re: Stall during warm-up (pastor)
you may want to check the idle compensation valve (IAC) it may be carboned up or frozen, on the throttle body is where it is located..
mo
