Headlight Switch not Illuminated on 94
What I want to know before I get in there is there a replaceable bulb that comes out. What kind of lamp is it, where to get it or a part number for it.
What am I in for.
The one bump in the road I did have was I could not get a socket on the 2- 7mm screws. And was not sure why as I had all the half sizes and nothing would work initially. The problem is the wall of the socket is to thick and cannot get deep enough to grab the screws. So I took one of my 7mm sockets (have 5 or 6) and ground down the end and part of the main body so I could have a thin wall socket. It worked great, socked still good just don’t crank on this one.
I still need a bulb. This is what it looks like. (New pictures, photobucket deleted)
BULB
SOCKET
The orange sleeve just comes right off so I can transfer it. I am going to be out tonight and going to check a parts store just for the heck of it.
http://www.ebay.com/itm/271047742407?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.donsbulbs.com/cgi-bin/r/b...x9.5d~ece.html
The dimensions for the 37 bulb is easily found just by searching using 37 and follow the choices. Once you get the hang of ID'ing the bulb base DONS is quite easy to use.
http://www.donsbulbs.com/cgi-bin/r/b...~ac-delco.html
You can modify the voltage requirements among other things after you ID the base correctly. I haven't used DONS BULBS identifications for many years but I've done it in the past. I had an industry wide bulb interchange that also included dash, switch and component bulbs for GM, MOPAR and FOMOCO and I can't seem to locate that. I believe it's on an old thumb drive and neither of my computer hard-drives.
10 Super Bright Clear 37 Incandescent Instrument Panel Lamp Light Bulb T5 | eBay
I got the bulb in but then I could not get the socket into the housing. So I switched out the lamp with the ASR light. Put the ASR bulb in the headlight switch, then installed the new bulb in the ASR position (a bit tight). All is in and working but the ASR light seems a little too bright. At this time my thinking is that the yellow colored sleeve is stretched a little too tight and hence makes it stretch more and get thinner letting to much light thru.
The manufacturing of today may not be exactly as it was done 20 years ago. I am still playing around with this but not sure if I can get things any better. Maybe GM made their own bulbs.
