Carefull when changing exhaust
Old Jul 31, 2002 | 10:29 PM
Ericthewolf's Avatar
Ericthewolf
Default Carefull when changing exhaust
If you look at how the origional exhaust comes off you need to pull it toward the rear of the vehicle about 6 inches or so. The front left pipe which connects directly to the cat and has the flange on the end when pulled backward directly contacts the shift linkage. This kinked my linkage beneath the rubber boot. It made the shifter sticky to shift. (auto tranny) I had to pull the boot back and un-kink and shoot with a little wd40, worked like a charm..
Old Jul 31, 2002 | 11:05 PM
Raysur's Avatar
Raysur
Default Re: Carefull when changing exhaust (Ericthewolf)
That's cool that you fixed it. I'll be doing this soon. Thanks for the hint. :cool:
Old Aug 1, 2002 | 12:45 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
That sounds like what happened to me, except I was still able to shift the car. It was only after that story I told youthat I had a problem :confused:
Glad it's fixed :cheers:
Old Aug 1, 2002 | 02:26 AM
imaruby's Avatar
imaruby
If you can raise the left side a couple inches it will clear the linkage.I did mine over a pit which made it a piece of cake. :cheers:
Old Aug 1, 2002 | 03:49 AM
MJ's Avatar
MJ
Default Re: Carefull when changing exhaust (imaruby)
Glad it worked out. :cheers:
Old Aug 1, 2002 | 08:59 AM
93TorchRedC4's Avatar
93TorchRedC4
:cheers: Thanks for the hint Eric! :seeya
To Carefull when changing exhaust
