TPS setting problem 87vet
Old Oct 18, 2014 | 12:25 AM
AJ123's Avatar
AJ123
Default TPS setting problem 87vet
Using a new multimeter and test tool from mid America best reading throttle closed I could get was .01.no change when throttle open. what volts should be from the connector wire unplugged from the sensor. .01 is what I get on black top the bottom connector reads 5.01 Are my settings on meter correct
is the plug bad . I have an extra plug. When I have time tomorrow I will connect Datamaster and check that way
Old Oct 18, 2014 | 12:44 AM
Cliff Harris's Avatar
Cliff Harris
The ECM supplies a 5 volt reference voltage on the blue wire. The black wire is ground, which also comes from the ECM. Put one probe on the black wire and the other on the red wire. Don't use some random metal part of the engine as ground reference because there is not a good connection between the engine and the ECM.
The polarity of the probes does not matter -- the important thing is the number. The meter will read minus if the probes are backwards, but that isn't important. As I like to say, the electrons don't care what color the insulation is.
Datamaster will tell you what the ECM is seeing. That's the important thing.
Old Oct 18, 2014 | 01:43 AM
AJ123's Avatar
AJ123
As can be seen the tool from Mid America keeps me from making a mistake connections are correct. I am trying to figure out whether the Sensor is bad or the connector wires need to be replaced. I am not getting a reading using it or without it .
Data master tomorrow
Old Oct 18, 2014 | 12:17 PM
AJ123's Avatar
AJ123
http://www.enduringautomotive.com/tps/
Using this link I feel the wires are ok. After breakfast I will try datamaster to see what the computer sees
Old Oct 18, 2014 | 01:57 PM
John A. Marker's Avatar
John A. Marker
The the Mid America adapter you do know that this gets plugged into the weatherpak on BOTH SIDES. It is like putting a 4" extension between two 12 inch extensions. Looking at one of your pictures, it is not plugged into the HOT end of the weatherpak....therefore your not getting any electricity to the TPS.
This has to be plugged in and the key turned to the ON position (car not running).
Old Oct 18, 2014 | 03:15 PM
AJ123's Avatar
AJ123
Correct you are . I tested it with it plugged in correctly. Data master shows no volts from TPS.
Old Oct 18, 2014 | 04:17 PM
AJ123's Avatar
AJ123
tester hooked up correctly no volts.
Old Oct 18, 2014 | 04:53 PM
WW7's Avatar
WW7
Electrical isn't my strong point , but if you have the 5 volt reference signal (Blue Wire) going into the TPS and your getting a reading of "0" out ,wouldn't that mean the TPS is bad.???....WW
Old Oct 18, 2014 | 05:18 PM
AJ123's Avatar
AJ123
Will find out soon trying to find one now
Old Oct 18, 2014 | 07:31 PM
AJ123's Avatar
AJ123
Installed new TPS set correctly.
After using Data Master engine cranks and does not fire. Data Master loaded it up.
Any thoughts. Did It damage the ECM..
To TPS setting problem 87vet
