87 wiring diagram from the tps going in to the ecm
Old 10-22-2014, 11:10 PM
AJ123
AJ123's Avatar
Default 87 wiring diagram from the tps going in to the ecm
Trying to track a possible short in wires. 87 wiring diagram from the tps going in to the ecm Looking for diagram. Looking for my shop manual. It is here some place.
Unable to set TPS
Thanks Steve
Old 10-23-2014, 12:04 AM
Cliff Harris
Cliff Harris's Avatar
Here ya go:
Old 10-23-2014, 12:54 AM
AJ123
AJ123's Avatar
Originally Posted by Cliff Harris
Here ya go:
Your the man Cliff thank you
Steve
Old 10-24-2014, 11:36 PM
AJ123
AJ123's Avatar
Still no signal at TPS.
The new ECM for some reason turns on cooling fan as soon as key is turned . Suspect this PepBoys ECM is crap.
Datamaster showed missing ecm
File Type: docx
Old 10-25-2014, 02:40 AM
Cliff Harris
Check for the 5 volt reference voltage on pin C of the TPS connector (gray wire). That voltage comes from the ECM. The ECM compares the TPS output on pin B to that voltage to determine the throttle position.
I would think that the only way you could get the "no PCM" error is if there is no data coming out on ALDL pin E.
Does your SES light work? It's controlled by the ECM so if it's working the ECM must be at least partially functional.
Old 10-25-2014, 05:08 PM
AJ123
AJ123's Avatar
SES light is on. C14 has power
checked wires from tps through loom in fuel injector wires on passenger side . Seam good.
sure it is something simple still searching.
last emc kep cooling fan on have a replacement in an hour.
Old 10-25-2014, 06:50 PM
AJ123
AJ123's Avatar
New ecm in got signal from wire. Set tps .54. Fan did not come on and stay on happy. Did not want to fire. Taking a break will recheck everything in an hour.
Old 10-26-2014, 02:50 PM
AJ123
AJ123's Avatar
Running great now Thanks for the Help
Cliff
To 87 wiring diagram from the tps going in to the ecm
Quick Reply: 87 wiring diagram from the tps going in to the ecm
