Temp
Old Oct 25, 2014 | 12:20 PM
jkann1's Avatar
jkann1
Default Temp
Hi, I have a 86 vette it seems to run warm temp gage says 218 to 230 when cruising. the cooling fan doesn't come until 227.. is this normal for the car.. or should I worry.. thanks
Old Oct 25, 2014 | 01:07 PM
rick lambert's Avatar
rick lambert
Actually it's close to normal, but I'd definetly check between the condenser and the radiator. Our C 4s are like a Hoover vacumn cleaner, they suck up everything from leaves, cig butts, plastic bags.
My 87 had a bunch of stuff. Does your vette have the auxillary fan, besides the normal fan?
Old Oct 25, 2014 | 03:15 PM
jkann1's Avatar
jkann1
yes I think so that's the outer fan right...I heard it come once.. I thing the thermostat don't open until 205.. I assume it a 195 t-stat but I will check the radiator for trash...Thanks for your time
Old Apr 17, 2020 | 02:01 PM
cgladish's Avatar
cgladish
i would have it replace ASAP. my current fan failure experience, as near as can be determined, has resulted in me needing
a new or rebuilt more. long, long, story, but i did experience several major engine overheats ( into the RED, 260°F ).
I've listed previously the saga leading up to this but, I've had two separate shops do a coolant dye test. both found coolant in the oil. with original set of heads, I've had two other sets installed ( both used, with the last set being magnafluxed ).
shop #3 feels that with the heads having been removed several times, along with the 3 - 4 major over heat cycles, the block
has been compromised. he quoted $11k for a rebuild. looking at a new LS3 crate motor ( $7600 from jegs ).
would also do the clutch at the same time ( still on the original at 162k miles ).
as it sits now, i could get maybe, $4k-$5k for it. with a new engine though, it's almost a new car ( zero miles engine & clutch ).
not that i have loose change laying around, but pay-pal will let me finance it. still have the labor costs though.
bottom line, fix that fan!
Old Apr 24, 2020 | 09:50 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
his temps are normal. possibly trash and dirty rad wich can be removed and cleaned.
whats this post about?
Old Apr 24, 2020 | 10:28 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Not sure but it is 5 1/2 years old.
Old Apr 24, 2020 | 10:39 AM
cgladish's Avatar
cgladish
silly me, i forgot to check to the posting date. my intent was to explain my recent experience with an overheating issue.
To Temp
