rapid fire plugs?
Old Nov 2, 2014 | 07:19 PM
mikewilson88's Avatar
mikewilson88
Default rapid fire plugs?
Ok so I just installed new plugs in my 85. I used ac Delco rapid fire gap at .035 and now it backfires through the intake when warming up if you pat the gas. Anyone have any idea what may be going on.
Old Nov 2, 2014 | 08:38 PM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
If it didn't have that issue before the plug change,wonder if
a ignition wire became crossed or a plug gap got closed up
when it was installed. Both have been know to happen,just
a thought.
Jimmy
Old Nov 2, 2014 | 09:58 PM
jv9999's Avatar
jv9999
I agree, either a crossed wire or a wire on the wrong plug. Check them: 1-8-4-3-6-5-7-2 clockwise on the distributor.
Old Nov 2, 2014 | 10:26 PM
mikewilson88
I'll check but I done them one plug and wire at a time and when it warms up to about 160 it stops
Old Nov 3, 2014 | 08:27 AM
aklim's Avatar
aklim
Plugs shouldn't do that unless you moved the distributor or something while you were there. Only other thing I can think of is you broke a wire or something. When I took my MAP sensor off, it ran like crap.
Old Nov 3, 2014 | 06:26 PM
TBSS/85vette's Avatar
TBSS/85vette
I have Rapid fire in my 85 and they work fine. No problems.
Old Nov 4, 2014 | 12:42 PM
wydopnthrtl's Avatar
wydopnthrtl
You might check for a vacuum leak. Maybe a hose got bumped and cracked or came off. Sometimes this can be a real pain to track down as the crack can be on the unseen side. And.. an 85 is past due for vacuum hose replacement too.
Old Nov 9, 2014 | 08:29 PM
mikewilson88
Ok so it has gotten a lot worse now at wide open throttle it stumbles really bad and will not clear out I exchanged the plug for Denso iridium parts store said the rapid fires were junk and theses were better. Anyways still no luck I have been reading a lot on here and think it may be the fuel pressure regulator the car has been sitting sine 2011 is it possible the diaphragm has dried out and cracked any help is greatly appreciated as I am Incredibly lost and aggravated now
Old Nov 9, 2014 | 09:11 PM
aklim's Avatar
aklim
Have scanner, will fix.
This is after you check fuel pressure
Old Nov 11, 2014 | 01:03 PM
ch@0s's Avatar
ch@0s
Recheck all your work and make sure the timing is not off. Where do you live. If you were near by I could help.
Old Nov 11, 2014 | 04:54 PM
c4cruiser's Avatar
c4cruiser
What specific plug did you get? The '85 should use Rapid Fire #1 and the gap should be .045. There are a number of Rapid Fire plugs (by number) and it's important to select the correct plug.
As far as the chain store parts guy and his "opinion", he's just trying to up-sell another plug and most likely has absolutely no idea what will be best in a specific engine. What Denso plug did he sell you?
If you think the fuel pressure regulator is bad, then get a fuel pressure gauge and attach it to the Schrader valve on the fule rail and let us know what pressures you see. Go to the local AutoZone and they will have "free rentals". If the line on the gauge is long enough, attach it and tape the gauge to the base of the windshield so you can check the pressure under different driving conditions.
Old Nov 12, 2014 | 06:29 PM
mikewilson88
Thanks for all of the help unfortunately I have returned the car to the shop where I bought it n got my money back they think the tank is clogged up they said they would check it out and if they can fix it I can come back in a few days and check it out n get it back thanks again and I will post what happens
To rapid fire plugs?
