Broken thermostat bolt
there are 2 options at this point from what I see...
drill it out and tap a new thread and get metal shavings all over the place...and IN everything....
or
pull the intake off to replace or repair it the RIGHT way.
Either way, you're screwed like a pooch.
Sorry 'bout that. Just a bad day to be you, that's all. Tomorrow should be better...
Good luck !
Cost was $130 as I recall and smiling when I paid it.
As for removing the bolt...and the extractor, HEAT is your friend. HEAT.
If you have access to a welder, you can weld up a "pile" on the broken off parts, then while it's hot grab the "pile" with Vise Grips and thread it out. It may help to heat the area of the casting w/a torch while welding and removing, since aluminum removes heat so quickly.
It MAY take the thread out w/it. That is not ideal, but it's O.K. as it still gets the bolt out, and you can helicoil it to return it to service.
The other option is to drill it out, but with the mixed metals in there now I'd think your chances of getting a straight and centered drill hole are pretty small. IIWM, I'd fire up my torch and my MIG and start welding. Drilling shavings are not an issue here; they aren't going anywhere that will hurt anything.
Either method could be done on the car.
Cost about 20 bucks plus manifold Gaskts and your free labor
Before I removed anything I would try to tap it around to tighten and then heat the bolt and surrounding area then touch a candle to the top of the broken stud and melt some wax over it with the intention of the melted wax being sucked into the threads, much like solder being sucked into a copper pipe joint.
Then I would try to tap the bolt out with a small drift or whatever I could get a bite on.
As some one mentioned above, place nut over broken bolt and weld inside nut until weld is flush with top of nut. You have to make sure you get down to the broken stud and that you're set hot enough, then just put a wrench on it and if done properly the bolt will back out.
If the bolt starts to come out and then get tight again, melt the candle wax on the bolt as stated above and keep easing it out.
