Funny business at WOT
Old Nov 5, 2014 | 09:31 PM
DanielRicany's Avatar
DanielRicany
Default Funny business at WOT
Hey guys, I took it out for a WOT blast today and the AFR was high 12s, low 13s. I wanted everything to be mid to high 12s so I went back to see what RPM it was going into the 13s at. Well the second time around it was at low 12s!
Also when I was data logging I noticed that a few times at 20 grams/sec it was like 126 and other times it was at 136...
Something weird is going on here.
Any ideas?
Old Nov 6, 2014 | 12:10 PM
Rohn's Avatar
Rohn
20 grams is not WOT. If the car is cammed it is sensitive to exhaust gas finding it way into the combustion chamber at lower RPMs. So that change in BLM/INT could be expected.
As far as WOT I would expect that to be more consistent than you witness. What is duty cycle for each episode? Possibly the FP is not keeping up or filter clogged partly.
Old Nov 6, 2014 | 12:45 PM
DanielRicany
I know that 20 grams is not WOT. The last time I checked the duty cycle it was pretty high up there. I'm on the edge of being able to still use 24 lb injectors I believe. I tried to get it go into the high BLMs today but I didn't have much success.
Old Nov 6, 2014 | 02:09 PM
tequilaboy's Avatar
tequilaboy
Your MAF is pegged at WOT, so above this point your tune is blindly fueling based on the LV8/pulsewidth table and PE tuning.
It will not be able to adapt to conditions, so sometimes it will be a bit richer or leaner depending upon the actual mass air flow which changes with the air density.
The LV8 will always decrease linearly as a function of rpm above 4800 rpm in a predictable pattern since the maf is pegged. Since this is predictable, it can be compensated for in the tune, but there will be no automatic correction for conditions.
Old Nov 7, 2014 | 12:29 AM
Cliff Harris's Avatar
Cliff Harris
I don't understand what you are referring to here: "it was like 126 and other times it was at 136".
If you're talking about INT and BLMs, then they are both fixed by the ECM at 128 when it's in open loop mode. If you're talking about BLMs, then...
There are 16 BLM cells, so you might have been bouncing between some of them. Note that the BLM cell boundaries changed with different BCCs, but these are the ones in my car:
Code:
; Block Learn Multiplier cell matrix at L001C:
;     700  1200 2000
;     RPM  RPM  RPM
; |  0 |  1 |  2 |  3 |
; ---------------------- 12 gm/sec
; |  4 |  5 |  6 |  7 |
; ---------------------- 22 gm/sec
; |  8 |  9 | 10 | 11 |
; ---------------------- 34 gm/sec
; | 12 | 13 | 14 | 15 |
Generally speaking, your engine operates on the diagonal: Cells 0, 5, 10 and 15. This follows from the relationship of RPM to air flow.
To Funny business at WOT
